P1000 Using a steering mount speedometer from 700 on the p1000????
MoneyMaynard
Huntington WV
  1. 1000 6 Crew
Is it possible to use the steering wheel mounted speedometer on the 700 on a 1000? And are they the same?
Reactions: ChadD
68,158
Hi,
Welcome to the club... Anything is possible...
I haven't seen anyone retrofit the older units to be on the steering wheel tilt.
Now, the newer 700's have this, however they will NOT work with the older ones.
Thanks.
MoneyMaynard
Huntington WV
  1. 1000 6 Crew
Hi,
Thanks.
Thank u for the answer. Reason I ask is I am a big dude, and I just picked up 1000-6 2024 model. When I get in I have the steering wheel tilted up pretty far and it blocks the Speedo. When I was at the dealer I checked out the 700 and saw the Speedo on the steering column. I could see it perfectly. Also they looked identical. So I figured somebody had tried the swap.
Reactions: ChadD
P1K5Dave
P1K5Dave
2,319
8,637
Petoskey, MI
Not the fix you're looking for, but if you run a tablet for nav you could run a GPS speedometer app and overlay it on your maps. Pretty much any size you want.
Or even if you don't use a tablet with maps, your phone on a mount with a speedo app.
I rarely look at my speedo
Reactions: ChadD
