P1000 Very Quick Elka Stage 3 Advice
Mopower58
Mopower58
CST is the Best!
79,418
706,150
Crystal Springs,Ms.
Hey guys, a pair of used Elka Stage 3 came up for sale which is rare up here, they came off a 1000-5. I have a 1000-3. Will they fit? and are they okay for use on a 1000-3?
Thanks
Depending on the weight, the spring rate might be a little different but they will physically fit.
T
Tincan
British Columbia, Canada
Okay that's what I was looking for, just to know they fit.... and the spring rate......I would think it would be different as the 1000-5 is a bit heavier. The reason I ask as the elka shows two different SKU numbers for the 5 and the 3 so they must be different in some way.
Well thank for the replies and if anybody else has anything else I'm all ears.
Reactions: Smitty335 and TxDoc
Mopower58
Mopower58
CST is the Best!
79,418
706,150
Crystal Springs,Ms.
Some of the P1K-5's had auto leveling rear shocks. The different part numbers are probably for the different spring rates.
Reactions: TxDoc
Mopower58
Mopower58
CST is the Best!
79,418
706,150
Crystal Springs,Ms.
Okay, good to know, not having known anything from the stocks, would I be missing out on anything that would make up for me getting the ones for my 1000-3???
No, you could probably use the same front Springs depending on front bumper,winch, and if it has dual batteries. If the weights of the P1K-5 and P1K-3 are pretty close you could bolt them on and ride.
Scrappapotamus
The Scrappapotamus
738
3,919
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
They're going to be miles ahead of what you're currently running, I have stage 5 shocks on my P1K-5 and night and day difference when the machine was new. Buy them, install them and pat yourself on the back before someone else scores them.
T
Tincan
Okay, sounds about right different part numbers for the slight difference in weights and spring rate which I just looked up. I'll ask about what was on the machine but can't see it having to much added as there is just not the many 1000's up here and mod's would be rare. It's all Polaris for the most part in this area. Thanks for your input guys, it's 2 hours to where they are so, see what I can do and go from there. Thanks again.
115,290
To easly get your answers just call Elka direct and they can tell you specifics.
On paper they should work tho
On a side note dont for get to hit reply when replying to someones question and when using there name type @Tincan or they may never know your responding to them.
5,406
24,778
Bring one of your shocks with, if the lengths are close to the same you're in. Also bring a bolt to see if it fits the shock hole properly.
