Wanted pioneer 500/700 factory front wheels
Chance135
Chance135
25
27
Southern Maine
I'm looking for a set of factory front wheels so that I can run the same size tire on all corners. Anyone have a set that's taking up space in the garage that they want to get rid of? Thanks.
266,578
I am using the factory rims front and rear and run the same tire all the way around no problems. Running 26 x 9 x 12's
Chance135
Chance135
25
27
Southern Maine
Thanks for your reply Jakal but I want to be able to rotate the tires since the rears tend to wear faster. The rear wheels won't work on the front, I tried and they rub.
Reactions: bobbyhill
266,578
Aha I understand now. If you don't get a cheap OEM solution may try STI HD4 rims with the 6+1 or 5+2 offset and run them all the way around, will keep it at 50" width that way. I think they are about $65 on RM ATV.
