Dirtstiffs-1000
Dirtstiffs-1000
1,725
6,230
hondasxs.com
Moxdmguy
65
417
53
Lone Jack, MO
Upgraded the stock Swamp Donkey with new Fusion speakers, Fusion Apollo head unit and Rockford Fosgate 4 channel amp under the driver’s seat. Sound quality is a big improvement especially when cruising down the road….
IMG 0453
Dirtstiffs-1000
Dirtstiffs-1000
1,725
6,230
hondasxs.com
Have a pic of your amp, model?
Reactions: Smittyp
NorthernJoe
NorthernJoe
385
1,484
Northern Ontario
Finally finished my ceiling install . I got the idea from @CumminsPusher rebuild thread. Its nice to have the extra lights. I added a wrecking yard sun-visor. I think it brightens up the interior, absorbs some of the sound and helps the anemic OEM heater. I'm thinking it will keep some of the summer heat out as well
IMG 2208
IMG 2210
To do this I first made brackets that I attached to the roof mounts
IMG 0112 2
Then I made a template by hot gluing many small pieces of wood together
IMG 0114 2
IMG 0113 2
Using this template I cut a piece of plywood, covered it with speaker cabinet cloth, installed lights that connect to my courtesy light switch, then I covered the top with 3/4 foil faced foam
IMG 2138
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
@Jankyeye , what is the vehicle sway with that setup? I see those every so often and think the vehicle sway on turns has to be horrible
You can feel it for sure. It’s not horrible going straight down the road. Averaged 13mpg running 60-65 mph. I’ll probably have the Talon on there more than the pioneer. That should be a bit lighter and lower profile so I’m hoping it will be better.
