Soaz1000
Soaz1000
171
946
Soaz
Let’s see them rock lights, also what spare tire carrier do you have?
I got that spare tire carrier at the dealer in Southern AZ where I bought the machine. It's made out of 14ga tubing and fits in the receiver on the machine. Unfortunately the guy that made them moved on.
212,838
My Viper 6000 winch will be here Friday from the Club Store and the key on harness. RK has some good stuff! I've got a Warren 4500 winch that I will take to the TO and try to find a new home for.
StewB
StewB
770
3,566
In all seriousness (which admittedly is unusual for me), I don't think it rises to quite that level of impacting how liberals think (if they do that at all). Consider that in some states, Nevada being an example, due to hunting regs, while you can carry a long gun in your vehicle with rounds in the magazine, you just can't have a round chambered. The AR in question may be "hammer down" on an empty chamber. The AR safety lever can't be moved to safe unless the weapon is cocked.
I think that's true. It's what my friend said. I lost all my guns in a tragic boat accident and can't remember.
StewB
StewB
770
3,566
I have been looking at options for the back. I like your screen, where did you get the material for that if you please?
jenk61 - I'll try to find the thread and post it for you. Some here found a custom shop that had very good deals. I went to Amazone and bought canvas sail needles, outdoor upholstery thread, a grommet kit, and a mesh cover for a dump truck. I also bought ball bungees. In the end, I made the rear mesh and several overhead mesh storage compartments. Was done a bit as a hobby, and it's all worked well.
bumperm
bumperm
1,931
6,829
Gardnerville, NV
Statistically speaking, there are more boating accidents per capita, resulting in more tragic loss of firearms, than any other type of accident (including kids stubbing their toes and skinning their knees running around barefoot*). Why the entire firearms industry can barely keep up with the horrific loss rate. Boats should be banned.
*Do kids still run around barefoot? We sure did - a lot. The fact mom didn't have money for shoes for us kids may have played into that some.
Soaz1000
Soaz1000
171
946
Soaz
Here is the thread that discusses the mesh windows.
@jenk61 if the mesh doesn't pan out might try the one from Shybull. Their on FB
Wellzy
Wellzy
269
900
SW Wisconsin
I have had my rear mesh on all last year, about 4000 miles, and I can say it cuts down on the amount of wind that comes in from the back, as you move forward due to the low pressure behind the windshield. Dust is going to blow around, no fix for that but this will reduce the amount of the back of the head wind you normally experience. If you do order one just follow my lead and make a note to eliminate the bottom grommets, except for the corners. This is such a low cost addition that does make a difference.
My friend with a CFMoto got a clear plastic rear "window" from the same company, and added the CFMoto logo to the window for, I think $10. I might get one of these for a mid cab panel right behind the front seats that can be taken out when passengers are in back.
View
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
Mesh panel hasn't really helped reduce dust for me.
I think a mid or rear plastic panel and door seals might be a better solution. And open the windshield a bit to draft through. Search dust ..
The upholstery guy is working on a front door seal kit.
More to come.
But hey, it's a buggy.
Cheers
JMynes
JMynes
553
3,267
Augusta, Maine
I started on my DIY switch panel. I figured I should cobble it up myself until I get the final layout, then either buy a CNC’d one from an expert, or just try hard to make it pretty.
I used ABS sheet and 1/8 x 1/4 stick on gasket from Amazon, and 10-24 well nuts from the hardware store, along with button head screws. All of which I had on hand from previous projects that may or may not have been completed.
4685E7F9 8800 49EC 941F 556F0F96AC59
C6746564 C87F 4A71 B0C2 1ED1EF14A9A7
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,258
hondasxs.com
View attachment 323713View attachment 323714
I like the look of your textured ABS panel, JMynes..
jenk61
jenk61
155
1,183
Southern Illinois
Made homemade back window from a $3.00 Walmart shower curtain and some Gorilla tape. It will do until I decide on the final solution. Got Superatv ready-fit winch installed. Ready fit does not equate to easy fit. Spent way too much time trying to install per the instruction. Finally took mounting plate off, installed it and then bolted winch on. Bolts are much easier to access this way. The bolts they included to mount it with were the wrong pitch. Everything looked good and worked well once I was finished
.PXL 20220314 203319071PXL 20220314 203333963MP 1PXL 20220314 172137231
JMynes
JMynes
553
3,267
Augusta, Maine
Adjusted the massive factory toe out to just a slight (1/8”) toe in. Two straight edges lashed to the wheels, a tape measure, and two wrenches.
Got about 4 threads exposed on each side. Had to move the steering wheel one spline counterclockwise to center it again.
It must be an optical illusion, because eyeballing it from the front it still looks like toe out.
