Thanks.You'll be fine with either. I use the stock tires with chains for plowing. They work excellent with the chains. Much better then the 27" vampires, which work decent as long as it's not icy. 👍
When the plow is raised there is only 6“ of clearance with using 27” Terrabite tires.
I was thinking of using the stock tires for plowing. The stock tires are 24” Vee-Rubber.
Has anyone used Terrabite for plowing?
Has anyone had any problems with the stock tires for plowing?
View attachment 304337 View attachment 304338
Are you concerned about the frame height because of tire size? Some manufacturers have plates that can account for machine height difference.When the plow is raised there is only 6“ of clearance with using 27” Terrabite tires.
