I have only had my ‘16 P1k5 about a year now. Last summer, after my first long mountain trail about 11,000‘ elev, my radiator was overheating. I cleaned, purged air, etc, but didn’t really help. So, I installed a 2nd radiator fan to help push the air thru the stock cooling system. And, on the one journey I took after that, it seemed to have taken care of the overheating problem. I hope. But, to watch the coolant temperature closer this summer, I just purchased a digital temp gauge to go in the coolant line. But, I have not decided which line to cut into and mount. The inlet to radiator, or the outlet, back to the engine. Here is the diagram from the service manual.
My thought is that if I install in the return line back to the engine, I can see the actual coolant temperature going back to the engine, and see how well the radiator, and new cooling fan are working.
But, on the other hand, if I install it in the radiator feed line, it will show the coolant temperature coming from the engine and thermostat, which I can then compare to the digital bar graph on the multifunction display.
This is the temperature indicator I will be installing. I got one for a 1” (25mm) ID coolant hose. I will just stick it to the dash somewhere near me.
thoughts?
thanks,
Tom
Surface TTO, Temperature, Black, Radiator Hose, 25mm | TrailTech
The TTO Digital Temperature Gauge Black, Radiator Hose, 25mm allows you to easily monitor your engine's temperature ensuring you that your engine is not over heat.
www.trailtech.net
thoughts?
thanks,
Tom
