P700 Will 1000 hi-low headlight switch fit in 700 hole?
1950Willys
1950Willys
71
151
Arkansas
I have purchased the 1000 LED headlights for my 700. Are the headlight switch bodies of the 1000 and 700 the same size? Want to keep it looking OEM if possible.
Reactions: Lady01
43,292
I believe there is actually a "kit" to install the 1000's set up on the newer 700's. I'll see if I can find it....
Reactions: Mudwing and Lady01
1950Willys
1950Willys
71
151
Arkansas
I decided to leave stock switch as is and control the low beams then place high beams on with my led light bar mounted on front bumper. That was I can have high and low on at same time without having to run diode between the switching wires to relay.
