Will 32 inch tires work
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Will 32 inch tires work with no rubbing on a stock talon 1000r? How tall are 32 inch black water evaluation?
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
yes. the R can even run 35" the X is limited to 30" unless you do forward arms.
thanks someone told me 31 max so if i went with 32 inch black water evaluation i would have no rubbing.
Code54
Code54
585
635
Hurricane West Virginia
32" Carnivores on stock 2 dr X without any rubbing or issues.
Slow-Poke
Slow-Poke
26
Nor Cal
No Rub even under flex 32"SunF cheapos.. went cheap to make sure i'd like them.
20210528 115928
