P700 Winching point in front of 700
G
Gizzy_44
24
31
Duhamel, Quebec
Just got my new 2021 700-2
i added the Honda warn winch
question:
Where do you hook up to tow vehicle in the front ?
Are there any D rings or hooks that mount on front for recovery?
thanx
Glock21user
Glock21user
1,825
9,092
Livingston county, Mi.
They are difficult to come by on these machines unless you use a short tree saver strap and get around a tube on the frame or a lower control arm in a pinch.
Whatever you do never ever ever wrap around two tubes of anything and try to pull.
The forces of pulling can collapse them together at worst or bend them at best.
insanetreefrog
insanetreefrog
51
140
Lowell, AR
I've had pretty good success using my front receiver mount with a shackle installed. Providers a good point to come back from a snatch block and "double up" your winch power.
PXL 20210331 235300422 PXL 20210331 235314707
insanetreefrog
insanetreefrog
51
140
Lowell, AR
Yes sir. Wasn't bad stuck and could've gotten out with a single line, but to be honest I wanted to use my snatch block and all to get out
Reactions: Buckshot07
Buckshot07
Buckshot07
19,724
202,965
I have to get a different 5/8 hitch pin or fabricate one from a bolt to use mine. All of mine are on a 45 and contact the winch mount before going through the receiver mount.
Reactions: Backwoods
Buckshot07
Buckshot07
19,724
202,965
Is the 2” receiver home made?
Ive just looked on Amazon and did not see one with bolting brackets on sides
It is a KFI front 2” receiver. Will work if you have a winch mount in which your winch is mounted underneath.
insanetreefrog
insanetreefrog
51
140
Lowell, AR
Had the same problem. I cut about an inch or so off one of mine, and that made it fit. Then I just drilled a new hole for the pin and it was good to go.
BigEarlX4
BigEarlX4
21
77
St. Helen, MI
  2. Talon X4 LV
I ordered a couple weldable tubing clamps, took a piece of steel, angled the ends to fit the clamps, then welded them up and then welded a clevis tab on. Took a couple hours and works great.
20201203 121228 HDR 2
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
I just hook my winch to their winch.
