With the key in accessory
David-1964
David-1964
38
99
Waterloo
Is it bad to set for a long time with the key in accessory position with the engine off, for instance to play the radio.
P
pappyo
597
2,400
How long is " long-time "?
Simular to leaving Lights On -- Will drain the Battery.
Long term non use with Key Out can drain battery ( Electronics have s slight draw )
Reactions: Backwoods
David-1964
David-1964
38
99
Waterloo
Beyond draining the battery, will it hurt the fuel pump, ignition system or other systems.
