P1000 Diagnostic Trouble Code(DTC), 2016-2020 Honda Pioneer 1000, ALL
Mark in Northern Iowa
467
2,089
Floyd County, Iowa
kramnella.wixsite.com
I could not find these all in one place, so I thought I would add them.
Check Engine Light blinking, Page 4-9.
Gear Indicator Light blinking, Page 11-11.
Electric Power Steering(EPS) Light blinking, Page 24-11.
Symptom Troubleshooting, Page 4-6.
HOW TO pull stored codes, page 4-8.
The (CEL)Check Engine Light blinks if there is a Fuel/Ignition issue.
DTC (Diagnostic Trouble Code)
In the Service Manual, DTC codes start on page 4-9
A long blink is a 10
A short blink is a 1
DTCFunction FailureSymptom/Fail-safe functionRefer to
page
1-1MAP sensor circuit low voltage
(less than 0.195 V)
. MAP sensor or its circuit malfunction
. Engine operates normally4-11
1-2MAP sensor circuit high voltage
(more than 3.804 V)
. Loose or poor contact of the sensor unit connector
. Engine operates normally4-13
7-1ECT sensor circuit low voltage
(less than 0.078 V)
. ECT sensor or its circuit malfunction
. Hard start at a low temperature
. Cooling fan turns on
4-14
7-2ECT sensor circuit high voltage
(more than 4.922 V)
. Loose or poor contact of the ECT sensor connector
. Cooling fan turns on 4-15 ECT sensor or its circuit malfunction
4-15
8-1TP sensor circuit low voltage ('16: less than 0.298 V, After '16: less than 0.200 V)
. TP sensor or its circuit malfunction
. Poor engine acceleration
. Gearshift function does not work
(1st gear only)
. Gear position indicator blinks
4-16
8-2TP sensor circuit high voltage (' 16: more than 4.912 V, After '16: less than 4.902 V)
(1st gear only)
4-18
9-1AT sensor circuit low voltage (less than 0.078 V)
. IAT sensor or its circuit malfunction
. Engine operates normally4-19
9-2IAT sensor circuit high voltage
(more than 4.922 V)
. Loose or poor contact of the IAT sensor connector
. Engine operates normally4-20
12-1Front fuel injector circuit malfunction
. Loose or poor contact of the front fuel injector connector
. Front fuel injector or its circuit malfunction
. Engine does not start
. Fuel injector, fuel pump and ignition shut down
4-21
13-1Rear fuel injector circuit malfunction
ignition shut down
4-22
21-102 sensor malfunction
. Loose or poor contact of the 02 sensor connector
. 02 sensor or its circuit malfunction
. Engine operates normally4-23
23-102 sensor heater circuit malfunction
. 02 sensor heater or its circuit malfunction
. Engine operates normally4-25
29-1IACV circuit malfunction
. Loose or poor contact of the IACV connector
. IACV or its circuit malfunction
. Rough idling4-26
33-2 *PCM EEPROM malfunction. Engine operates normally4-28
44-1EOT sensor circuit low voltage (less than 0.059 V)
. EOT sensor or its circuit malfunction
. Gearshift function works normally
11-30
44-2EOT sensor circuit high voltage
(more than 4.844 V)
. Loose or poor contact of the EOT sensor connector
. Engine operates below
3,000 rpm
11-31
64-1Drive power circuit low voltage (less than 6.5 V when the ignition switch is ON (I))
. Blown IGN fuse (15 A)
. Ignition relay stuck open or its circuit malfunction
. Engine does not start4-28
64-2Drive power circuit high voltage (more than 8.0 V when the ignition switch is OFF (0))
. Ignition relay stuck ON or its circuit malfunction
. Engine operates normally4-29
66-1Rear VS sensor no signal
. Loose or poor contact of the rear VS sensor connector
. Rear VS sensor or its circuit malfunction
(1st gear only)
11-38
67-1Front VS sensor no signal
. Loose or poor contact of the front VS sensor connector
. Front VS sensor or its circuit malfunction
(1st gear only)
11-40
81-1Sub-transmission position switch malfunction
. Sub-transmission position switch or its circuit
malfunction
. Gearshift function does not work11-45
83-1Clutch line EOP sensor low voltage
. Clutch line EOP sensor or its circuit malfunction
. Engine operates normally11-15
83-2Clutch line EOP sensor high voltage
. Loose or poor contact of the clutch line EOP sensor connector
. Engine operates normally11-17
101-1Throttle release angle sensor circuit low voltage
. Throttle release angle sensor or its circuit malfunction
. Engine speed is limited4-30
101-2Throttle release angle sensor circuit high voltage
. Loose or poor contact of the throttle release angle sensor connector
. Engine speed is limited4-31
102-1Abnormal throttle valve position with the throttle pedal released
. Sticking throttle valve
. Engine speed is limited4-32
* The MIL does not blink (OTC can be readout/erased only by MCS).
Have a good day
467
2,089
Floyd County, Iowa
The gear indicator light blinks if there is a transmission or driveline issue.
DCT (Dual Clutch Transmission)
In the Service Manual, DCT codes start on page 11-11
page
4-1Dual clutch PC solenoid valve malfunction
. Loose or poor contact of the dual clutch PC solenoid valve connector
. Dual clutch PC solenoid valve or its circuit
malfunction
. Gearshift function does not work11-14
4-2Dual clutch PC solenoid valve drive circuit
malfunction
malfunction
. Faulty drive circuit in the PCM
(1st gear only)
4-16
(1st gear only)
4-18
9-1Clutch line EOP sensor low voltage ('16: less than 0.049 V, After '16: less than 0.298 V)
. Gearshift function works normally11-15
9-2Clutch line EOP sensor high voltage ('16: more than 4.771 V, After '16: less than 4.702 V)
sensor connector
. Gearshift function works normally11-17
15-1Shift solenoid valve 1 malfunction
. Loose or poor contact of the linear/shift
solenoid wire harness connector
. Shift solenoid valve 1 or its circuit malfunction
(1st or 2nd gear only)
11-18
16-1Shift solenoid valve 2 malfunction
. Loose or poor contact of the solenoid valve connector
. Shift solenoid valve 2 or its circuit malfunction
11-19
21-1Shift spindle angle sensor circuit low voltage
('16:less than 0.337 V, After '16: less than 0.293 V)
. Loose or poor contact of the shift spindle angle sensor connector
. Shift spindle angle sensor or its circuit malfunction
(1st gear only)
11-21
21-2Shift spindle angle sensor circuit high voltage
('16: more than 4.790 V, After '16: less than 4.971 V)
(1st gear only)
11-23
22-1Shift spindle operation malfunction (after operating gearshift mechanism)
. Control motor or its circuit malfunction
(1st gear only)
11-23
23-1Shift spindle operation malfunction (while
. Shift spindle angle sensor installation problem
. Gearshift function does not work11-24
24-1Shift control motor drive circuit malfunction
. Loose or poor contact of the shift control motor connector
27-1Shift drum position malfunction
. TR sensor or its circuit malfunction
. Gearshift mechanism malfunction
(1st gear only)
11-26
31-1Shift control input power low voltage (less than 10.67 V)
. Faulty fail safe relay in the PCM
. Blown CONT M fuse (30 A)
. Loose or poor contact of the PCM 5P (Black) connector
. Gearshift function does not work11-27
31-2
(After '16)
. 2WD mode only4-28
31-3
(After '16)
. 2WD mode only4-29
32-1Fail-safe relay circuit malfunction
. Faulty fail safe relay circuit in the PCM
. Gearshift function does not work11-28
42-1Shift switch malfunction
. Loose or poor contact of the shift switch connector
. Shift switch or its circuit malfunction
(1st gear only)
11-28
(less than 0.059 V)
. Gearshift function works normally11-30
44-2EOT sensor circuit high voltage ('16: more than
4.844 V, After '16: less than 4.922 V)
. Loose or poor contact of the EQT sensor
connector
. EQT sensor or its circuit malfunction
. Gearshift function works normally11-31
47-1No.1 clutch EOP sensor low voltage
. No.1 clutch EOP sensor or its circuit malfunction
(2nd gear only)
11-31
47-2No.1 clutch EOP sensor high voltage
. Loose or poor contact of the No.1 clutch EOP
sensor connector
(2nd gear only)
11-33
48-1No.2 clutch EOP sensor low voltage
. No.2 clutch EOP sensor or its circuit malfunction
(1st gear only)
11-31
48-2No.2 clutch EOP sensor high voltage
. Loose or poor contact of the No.2 clutch EOP
sensor connector
(1st gear only)
11-33
51-1TR sensor low voltage
. Loose or poor contact of the TR sensor connector
(1st gear only)
11-34
51-2TR sensor high voltage
(1st gear only)
11-36
52-1Neutral switch stuck OFF
. Loose or poor contact of the neutral switch connector
. Neutral switch or its circuit malfunction
(1st gear only)
11-36
52-2Neutral switch stuck ON
(1st gear only)
11-37
57-1Gearshift mechanism malfunction
. Gearshift function does not work11-37
57-2Gear position malfunction Jumps out of gear)
62-1No.1 or No.2 clutch oil pressure high
. No.1 or No.2 clutch EOP sensor malfunction
. Faulty clutch oil circuit
(1st gear only)
11-38
(1st gear only)
11-40
73-1Orifice control solenoid valve malfunction
. Orifice control solenoid valve or its circuit
malfunction
. Gearshift function works normally11-43
74-1Shift solenoid valve oil pressure logic error
. Faulty shift solenoid valve 1 and/or 2
. Faulty clutch control body
11-44
81-1Sub-transmission switches malfunction (Low and drive switches remain on simultaneously for more than 1.5 seconds)
. Sub-transmission switch or its circuit malfunction
Have a good day
467
2,089
Floyd County, Iowa
No Blink Troubleshooting
Symptom Troubleshooting page 4-6
SymptomDiagnosis procedureAlso check for
Engine cranks but won't start
(No OTC and MIL blinking)
1. Inspect the ignition system
(page 5-6).
2. Inspect the fuel supply system
(page 7-10).
. Intake air leak
. Contaminated/deteriorated fuel
. Faulty fuel injector
. IACV stuck closed
(No fuel pump operation
sound when turning the
ignition switch to ON (I))
1. PCM power/ground circuits
malfunction (page 4-37).
2. Inspect the fuel pump system
(page 7-10).
. Open circuit in the power input (Red/white) and/
or ground (Green) wire of the PCM
. Faulty ignition relay or related circuit
. Faulty ignition switch or related circuit
. Blown Fl fuse (10 A)
Engine stalls, hard to start,
rough idling
1. Check the idle speed
(page 3-17).
2. Check the IACV (page 7-26).
3. Inspect the fuel supply system
(page 7-6).
. Restricted fuel feed hose
. Intake air leak
. Restricted fuel tank breather hose
. Faulty ignition system
Backfiring or misfiring during
acceleration
Check the ignition system.. Faulty ignition system
Poor performance
(driveability) and poor fuel
economy
1. Inspect the fuel supply system
(page 7-6).
2. Check the air cleaner for
clogging (page 3-7).
. Pinched or clogged fuel feed hose
Idle speed is below
specifications or fast idle too
low (No OTC and MIL
blinking)
(page 7-10).
2. Check the idle speed
(page 3-17).
3. Check the IACV (page 7-26).
4. Check the ignition system (page
5-6).
. Valve clearance
Idle speed is above
high (No OTC and MIL
blinking)
(page 3-17)
2. Check the accelerator pedal operation and pedal free play
(page 3-6).
5-6).
5. Check the air gleaner element
(page 3-7).
. IACV stuck opened
. Intake air leak
. Engine top end problem
. Valve clearance
MIL stays on but no DTCs
set, or MIL never comes ON
at all
Troubleshoot the MIL circuit
(page 4-33).
Have a good day
467
2,089
Floyd County, Iowa
Figured this should be added here.
No Flash Codes?
Have you tried to see if there are any stored faults?
In the Service Manual, page 4-8 shows how to pull stored codes.
This is from page 4-8
When retrieving the stored OTC, refer to the following procedure.
Remove the OLC from the dummy connector (page 4-8).
Short the OLC [1] using the special tool.
TOOL:
SCS service connector [2] 070PZ-2Y30100
CONNECTION: Brown/red - Green
Turn the ignition switch ON (I), read and note the MIL blinks, and refer to the
troubleshooting index:
  • PGM Fl system: page 4-9
  • OCT system: page 11-11
NOTE:
• If the PCM has any OTC in its memory, the MIL will start blinking.
The special tool they talk about is just a jumper wire.
jump: Brown/red - Green
DTC connector short
Then turn on ignition switch
count the flashes
Have a good day
467
2,089
Floyd County, Iowa
And learned about these today while helping another owner.
I will try and get them(2 Pages of codes) posted later, but for now....
The Electric Power Steering(EPS) light blinks if there is a Power Steering issue.
In the Service Manual, DCT codes start on page 24-11
Have a good day
