![Eric450X](/data/avatars/m/31/31701.jpg?1648658126)
So I am a long-time lurker here and have finally become part of the owners club. I recently picked up a low mile 2021 1000-5 that I have been slowly modifying for the last couple of months. My first priority was to build an auxiliary electrical system to handle any lights or radios that I will be addIng later. I wanted a plug-and-play setup that would allow me to easily add accessories without having a nest of wires under the hood. Here is what I have come up with.
Mod #1 - New Snorkel Intake
I needed to make room for the electrical panel so I used a 3" to 2.5" rubber reducer (Spectre Reducer) for an air intake that can be purchased at Autozone, Advance Auto, O'Reily's etc. That attaches to the air intake on the Pioneer on the 3" end and a 2" PVC 90 degree street elbow on the other end. A 3" to 2" PVC reducer goes on the end of the elbow to allow the prefilter to be used. This opened up the airbox area to allow for the auxiliary panel to be built.
Mod #2 - 2nd Battery Install
This is the typical 2nd battery install. A Tru Isolator and a 2nd battery were added.
Mod #3 - Auxiliary Electrical Panel
I wanted the ability to have relays for the higher amperage accessories so I choose a Bussman 15305-2-2-4 relay/fuse box which has 5 fused/relay circuits and 5 fused circuits. I followed the builds of a couple of guys I found on a Tacoma Forum and Youtube to help set up my system.
Tacoma World Bussman Relay Box Build Thread
Youtube Fuse Box Wiring Video
I won't bore you with all the details of the build but you can see how it is done in the links. I opted for a Honda SXS Auxiliary Battery Switch so I can power up the panel either with a key on function or as an auxiliary function if I don't want the primary electrical system powered. I used a $2.00 cutting board from Walmart as the base and was able to fit everything electrical on it. The harness in the picture will go to the 5 switches for the 5 relays. I still need to build the harness for the fuse side.
Now when I want to add an accessory all I need to do is mount the accessory, run the wires (in a loom), install the connector, and plug it in. If you made it this far, thanks for looking. If you have any questions, let me know.
![Image 50739201 Image 50739201](https://hondasxs.com/data/attachments/330/330639-816774c9b8b1418dc91232c1f1ceb312.jpg)
![Image 67206657 Image 67206657](https://hondasxs.com/data/attachments/330/330634-e9251deebd89e5a8cfa78da8b711f318.jpg)
![Image 50768897 Image 50768897](https://hondasxs.com/data/attachments/330/330635-aeb76237f7133fa31f4688344e53b44a.jpg)
![Image 67215617 Image 67215617](https://hondasxs.com/data/attachments/330/330636-a9c019fd96b30bb98cb45a7dd6d0dfab.jpg)
![Image 67195905 Image 67195905](https://hondasxs.com/data/attachments/330/330637-e44730f7a042de28a39b2b9d41ebb42b.jpg)
![Image 67182337 Image 67182337](https://hondasxs.com/data/attachments/330/330638-e3cf5abfaee4cf13138a63bf0683c4e5.jpg)
