P1000 1000-6 Illuminated Headlight Switch ?
Silverbullet40
Silverbullet40
12
47
Leavenworth, In.
  1. 1000 6 Crew
Has anyone seen or know of an illuminated headlight switch that will replace the large toggle switch on the P1000-6 ? I don't understand why Honda would install a non-lit headlight dimmer switch. Kind of hard to find in the dark. I've seen some on amazon for the CanAm that I could use with the Club oversized switch blank, but i'm not sure about the wiring since the stock switch is not illuminated. Any electrical Gurus out there that can help ?
Reactions: NewHere2
Silverbullet40
Silverbullet40
12
47
Leavenworth, In.
  1. 1000 6 Crew
All of the switches in the Forest model are back-lit. The only problem is the wiring is not there in the harness to make it plug and play.
The connector is the same and the switch is the same size.
Any way you could show a schematic for wiring the Forest switch to work in the 1000-6. I can modify the switch harness if I know what I need.
Reactions: NewHere2 and Lady01
No.
Yours is a 2 pin connector.
The lighted ones are 4 or 6 pin connectors.
Going to have to cut off the connectors and manually connect then. Then supply power and ground for the led circuit.
I can't confirm or deny, but I believe the connectors on the harness side are the same lighted or not. The two light pins just aren't populated.
I'll look tomorrow
63,987
I'll look tomorrow
The illuminated headlight switch is a 6 pin
The non illuminated headlight switch is a 4 pin.
The 2 additional wires just need + & -
Silverbullet40
Silverbullet40
12
47
Leavenworth, In.
  1. 1000 6 Crew
Which year P1000 Forest Edition has the backlit switch ? I want to make sure I order the right one. I looked on line but they dont specify backlit anywhere I could find.
Dirtstiffs-1000
Dirtstiffs-1000
1,562
5,692
hondasxs.com
For whatever reason the switch part numbers are different, could be wiring length, connector or supplier.
The harness would be the entire wiring harness, there is no separate dash/swithc harness.
Sorry for the troubleshooting squirrel.. thanks
