P500 15 p500 will not start
Hazen91
6
23
Clovis nm
Hi I bought a non running pioneer 500 from a auction. When I got it home I went over itand changed the gas and spark plug. it has fuel spraying out of the injector and spark according to an inline spark tester. When I’m turning it over it sounds like it’s so close to starting but didn’t. Every now and then it will almost backfire but that’s it. I’m at a loss any help would be appreciated thanks
107,828
You might be still pulling some nasty gas that was in the fuel system. How is the air filter? Was it swamped? spark arrester clean? Easy stuff to check off the list.
What year, milage?
BTW Welcome from Michigan. We like pics For proof. Pics Or It Didn't Happen!
Dave75
Dave75
123
500
At this point remove the spark plug and see if there is fuel on it. Do a compression test. Someone here will know what it should be. I would be looking for a minimum 100 psi.
Good luck.
Need to post photos.
906UP
906UP
13,152
122,889
da Yoop
Ok just did a compression test and it’s at 55psi. How tuff is a top end rebuild on these? Any tricks? Can it be done in the bike?
No tricks, the Honda Service manual is available on the site for contributing members, probably cheaper than buying a manual from Honda or Ebay.
Keep in mind, these things have an automatic decompression gadget on the cam, a compression test can be misleading. Have you tried spraying some carb clean down the throttle body and see if it will start?
Keebler
Keebler
246
836
St Charles, Mo
Before doing a top end job I would check the valve adjustment. At 326 miles I wouldn't expect a problem but who knows! If you don't want to check the valve adjustment you could first squirt some oil in the spark plug hole and redo the compression test, if the compression does not increase then a value adjustment would be the next step, then the compression rechecked.
Hazen91
6
23
Clovis nm
I have heard about the automatic decompression thing but I couldn’t find a whole lot of info on it. I have sprayed some carb clean and it didn’t start
Hazen91
6
23
Clovis nm
I didn’t think about the oil in the cylinder that’s a good idea.
906UP
906UP
13,152
122,889
da Yoop
Pic from the service manual, at slow, cranking rpm it holds the exhaust valve open a little longer so the starter can spin the engine, once the engine fires centrifugal force overcomes the decompression lobe so it doesn't contact the valve. This is why a compression test will always show low. At the mileage you stated I would look elsewhere, I doubt it needs a top end.
Cam
906UP
906UP
13,152
122,889
da Yoop
Many years ago my step dad had a Foreman that wouldn't start, backfire occasionally. It ended up being the voltage regulator, it was shorted internally and not creating good spark. Easy to check, unplug the voltage regulator and see if it will start. Make sure you have a good, charged battery.
Buggyman
Buggyman
35,170
299,869
ne. ohio
welcome from Ohio
K
Kwb
12
29
Edmonton
Hi bought 2017 non runner would start some times but if gave starting fluid it would start traced problem to ground bolt on engine block wires felt tight but used wrench and bolt was stripped put longer one in darts great now
