P500 P500 engine code help!
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
500 won’t start and the engine light is blinking 6 long and 4 short. Screen wouldnt turn off til I disconnect the ground. When I put the ground back on it did nothing but the screen would shut off. Then about 15 minutes later it tried to start but was weak. Battery is new and it just came from an engine out stator replacement a month ago. Any help would be appreciated.
DRZRon1
DRZRon1
844
2,694
PA
besides pics cuz u may be asking for a friend... basics for now
year, mileage, hammered, swamped, etc. - u have since new
so did it run since stator replaced? why did stator get replaced?
battery load test or as he said above - put a charger on it
you ever see smoke from the wiring
check all grounds and cables
then - hate to say it all connectors\main wiring around where engine came out
always more to the story
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
I took the key out of it and the screen was still on. I run it everyday. 15,600 miles no water or mud problems. The machine is still in the field. I haven’t got it towed in yet to look again at it. Dealer did the engine out stator replacement. Battery is 12.2 volts with the charger on now. 30 fuse is good. Bat is only charging to 12.7 and it won’t try to start.
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
Called the dealer he said the codes were voltage related. i took half a day to get the voltage up to 13. Still wouldnt try. Then a couple taps from mr hammer on the starter and she fired up.
