P500 Need help with electrical plan
futzin
futzin
3,157
22,710
Kentucky
Finished the bumper/winch install.
20240227 181030
Wired up the Aux 8 components. Connected the horn and the lighted mirrors. What do I need to do to make the horn activate only during button push? Currently have the two supplied wires to the + and - on the Aux control panel.
20240227 185008
Tested a 3' whip. Battery in the remote may be dead, this is all they would do. Wires don't reach to front; I'll guess I'll splice more wire in . . .
20240227 191612
906UP
906UP
13,026
121,441
da Yoop
You need to program that button as a momentary switch, that way it's only on when the button is pressed. The pamphlet that came with the Auxbeam will explain it, it's pretty simple
futzin
futzin
3,157
22,710
Kentucky
Another question:
I'm pretty sure I'll relocate the cubes to the rear roof corners. Fairly common for me to remove the Honda roof.
For quick disconnect/reconnect, are bullet splice connectors a good option? Others?
906UP
906UP
13,026
121,441
da Yoop
silvertrd09
silvertrd09
227
1,261
Texas
Power steering kit not playing well with RB3 steering rack.
Shaft knuckle narrowly misses brake reservoir (normal) but rubbing hard some brake gizmo.
I can maybe move the mounting plate 1/8", but it won't be enough.
Got the EZ steer in tonight but the short steering arm is hitting on the brake reservoir and moving it a bit. I don't have a RB3 kit. So not sure what's going on. In the morning I'll move the mounting plate over like you did. Don't think I can move the reservoir.
futzin
futzin
3,157
22,710
Kentucky
Yeah, the tolerances are tight. Pretty much have to shift the bracket to passenger as much as possible. I had my wife hold it there while I dogged it down, but others have used a ratchet strap which would be better, prolly.
Good luck.
The Green Goat
The Green Goat
1,750
12,388
Ohio
Good luck.
If I ever have to do it again, I'm putting the plate in first and drilling a self-tapper through it to hold it in place.
silvertrd09
silvertrd09
227
1,261
Texas
Good luck.
I ended up banging the s**t out of the mounting plate where the wing nut is in the pic and got the lower shaft to clear.
Putting a self tapping screw would not be a bad idea. 👍
20240302 110539
906UP
906UP
13,026
121,441
da Yoop
265,551
I just received several parts from the club store for setting up a new build. Going with the single 80 Amp Relay to fuse box with remote control switch harness for full off or Key-On Power or, Full time On Power options. Here a very basic diagram of theses 4 parts to the main battery.
Relay / Isolator : 80-AMP Battery Isolator or Relay - Compare to Stinger brand.
Relay Control Switch: Pre-Wired Relay Control Switch for AUX and Key-on usage. For Stinger, Cole Hersee or any.
Fuse Box: Fuse box with negative bus. 6 or 12 fuse unit, includes variety of fuses. FuseBox
Key on Power Pigtail: 2022+ Honda Power ACC pin for Key-on power. Pioneer, Talon
As this would apply to a Pioneer 500 would only need one each Positive & Negative cable 4 or 6 gauge to the front Relay(POS) & Fusebox (NEG)
Diagram of Relay 3 Way Switch and fuse box
Here is a workbench setup sans Key-on power plugged in.
20240304 181819
futzin
futzin
3,157
22,710
Kentucky
You’re making some head way with Futzin’ …. You got a long way to go with me! 🤣🤣
Well let's see:
Off the top of my head, you've installed the Torq Locker, replaced your fuel pump assembly, identified and corrected the roll cage issue, suggested the use of push pins for the 520 Quick Shield install, came up with and implemented a speaker mount for the JBL Xtreme, mounted a rear cargo box. I'm quite sure I'm missing some stuff.
KyGal83
KyGal83
7,655
76,755
Kentucky
Well let's see:
I did do those things.. 🤔. Only a couple are mechanical… but I am damn proud of that Torq locker install! #girlpower ✊🏻
You on the other hand are on your 3rd buggy overhaul, did more than 1/2 the upgrades to mine also, 3rd winch install, in the middle of a major rewiring plan, Mudbuster installs, power steering installs… and let’s not forget 4… 4 Reverse override mods. Come on… you’re a professional, I am still in apprentice mode. 🤣
That also reminds me I need to finish the write up on my fuel assembly replacement. (Adds to the to do list)
