P500 Need help with electrical plan
futzin
futzin
3,157
22,708
Kentucky
Power steering kit not playing well with RB3 steering rack.
Shaft knuckle narrowly misses brake reservoir (normal) but rubbing hard some brake gizmo.
20240217 132856
20240217 133321
I can maybe move the mounting plate 1/8", but it won't be enough.
20240217 133346
futzin
futzin
3,157
22,708
Kentucky
rustyneversleeps
rustyneversleeps
381
1,833
Montana
Critter has the Crossroads phone holder, so I tried it.
A strong possibility.
Could also relocate the MT/AT switch and cover that hole and the Allen bolt head with the switch panel. Would look pretty good.
Looks good! I’m thinking I might try to mount mine left of the electronic display in that little trapezoid thing haha
IMG 1987
futzin
futzin
3,157
22,708
Kentucky
Ok, been looking for a little while, hopefully find them on sale soon.
Installed mine, having worse clearance issues than prior installs. Might be due to the aftermarket steering rack. Or,
Can u check the short steering arm in the kit to see if it is symmetrical? It looks it, but I saw (afterwards) where someone mentioned the connections were different on each end...
futzin
futzin
3,157
22,708
Kentucky
Finished up the PS install, started on the winch install.
Got the remote plug and the rocker switch mounted and wired up.
Need to buy cable for the run from solenoid to battery, hopefully tomorrow.
20240218 181348
20240218 193832
futzin
futzin
3,157
22,708
Kentucky
Got the winch wired up and bench tested; all good.
Strongmade bumper with winch install next week. Then can move on to wiring up the Aux 8 and accessories.
Anyone ever use ferrule connectors? Saw a guy on TooYube using them on an Aux, looks like a good idea.
Smittyp
Smittyp
484
3,256
Morgan co. Tennessee
I used them when I installed my Aux 8. They work great and very easy to install.
906UP
906UP
13,025
121,438
da Yoop
Yup, I did on all mine....but I had the crimper & ferrules already from the SCKMM Co
silvertrd09
silvertrd09
227
1,261
Texas
I'm out at the ranch, probably won't be back until Friday the 23rd.
Reactions: NewHere2 and futzin
silvertrd09
silvertrd09
227
1,261
Texas
Back from the ranch a day early. Had some internet problems but Att. Is back on now. The short steering arm seem symmetrical. Each end is about 2 1/8" long. Only difference is the bolt is screwed in on opposite sides
20240222 130932
  • Love
futzin
futzin
3,157
22,708
Kentucky
Got my 4ga cables to the solenoid squared away. Installed Strong Made front bumper and shackle mounts. Gotta get longer bolts to mount the winch, but it's ready.
20240226 161655
20240226 170643
Almost Aux Time . . .
osobad
osobad
6,731
59,325
Tampa Bay Florida
I use them whenever you have that kind of connection. Stereo ect. You can get a kit with all different sizes and crimping tool off Amazon. Getting ready to install my Auxbeam and will use the ferrules.
NTCPrezJB
NTCPrezJB
President of #NTC
100,504
898,132
Canton, OH
Probably a dumb question but I’m gonna ask it anyway…
The ferrules obviously get crimped with the tool so am I right to assume they don’t get soldered at all?
