P500 Help With Diagnosis
futzin
futzin
3,157
22,712
Kentucky
Do I need to remove the steering box, or should I start by removing the inner tie rods, and inspecting?
Reactions: NTCPrezJB
906UP
906UP
13,026
121,451
da Yoop
I may have missed it if it was covered earlier..... have you checked the knuckle to see if it's bent, specifically where the tie rod attaches
futzin
futzin
3,157
22,712
Kentucky
Left inner steering arm bent at the ball (se pic)
This member had a hard hit at speed, damaging several components of his steering rack. He replaced.
My situation was different: pinched and stressed at full steering lock with force applied to steering wheel. Is this a pic of the inner tie rod? Could this be my issue?
lee
lee
Village Idiot
2,334
13,096
Springfield Ohio
Go here:
Order the CONN TUBE band and pull the boot to inspect.
The CONN TUBE band will allow you to reassemble the boot with out a full disassembly.
(band size is the same for the P500)
futzin
futzin
3,157
22,712
Kentucky
Go here:
Retracted the boot, the shaft is fine. That rear upper a-arm mount is bent more than first noticed.
Driver's side:
20231012 152551
Passenger side:
20231012 152529
Am I correct in thinking that it needs to be beaten back into alignment, then welded?
906UP
906UP
13,026
121,451
da Yoop
Are you talking about the area circled? It looks like it's torn loose a bit, but yah.....smack it straight with a hammer and weld it.
906UP
906UP
13,026
121,451
da Yoop
Yes, that's right. Do you feel like this would cause my toe-out issue?
It could, it's hard to see how far it's bent from the pic. I would suggest measuring from the A arm to a point on each side to get a real picture...... example, measure from the ball joint to the center of the rear wheel on both sides and compare
lee
lee
Village Idiot
2,334
13,096
Springfield Ohio
Try measuring from left to right.
The back side of the front mount and the front side of the back mount are clear side to side.
The measurements should be the same.
You could jack up the front end, drop the upper arm frame bolts (on the side that you think is wonky) and the holes should line up front to back.
Make sure they line up before you start welding.
The Green Goat
The Green Goat
1,750
12,389
Ohio
You jump a tooth in the rack?
Reactions: KyGal83
futzin
futzin
3,157
22,712
Kentucky
Beats me, but increasingly looking like a steering rack issue, I guess.
Trying to knock out the easier, more accessible stuff first, but even that is taking forever. Special thanks to KyGal for her sharp eyes thus far.
Trying to get a buddy to do the alignment 'persuasion' and welding...
