P500 Need help
marty lawson
15
Cushing texas
I have p500 it idles but no accelartion an will not shift into no gears showing code 18 N light flashes have changed TP sensor angel sensor no change checked battery too can i please get some help
Buggyman
Buggyman
34,936
298,144
ne. ohio
welcome from Ohio. I'm sure one of these gurus will be along to help out soon. probably going to need more info as year ,miles .
107,410
Welcome from the once not run by Commy’s Michigan!
Need pics of your rig to start with!
Pics Or It Didnt Happen!
906UP
906UP
13,126
122,602
da Yoop
There is no code 18 in the service manual, there is a code 8-1, is this what your referring to?
Also, only one post is needed, multiple posts for the same issue just confuses those trying to help you. Delete one or the other please.
906UP
906UP
13,126
122,602
da Yoop
marty lawson
15
Cushing texas
I changed TP sensor and angel sensor i dont know how to delete i am not very good useing smartphone
906UP
906UP
13,126
122,602
da Yoop
Use the troubleshooting guide I posted and report back with the results. Grab a DVOM (digital volt ohm meter) and test instead of throwing parts at it. If you don't have one, get one or find a friend who has one to help
marty lawson
15
Cushing texas
I
I ordered a code reader for 2017 p500
906UP
906UP
13,126
122,602
da Yoop
I
A "code reader".....????
Not sure there is such a thing for a Honda but OK.....
The code only points you to the system with the fault. You'll still need to troubleshoot the system. Most likely it's a bad connection or ground, component failures are on the rare side with these bikes
Reactions: trigger and Smittyp
Neohio
Neohio
Beast of the East
13,422
65,856
Painesville Ohio
I
Something like this?
Reactions: Smittyp
