P500 Help With Diagnosis
futzin
futzin
3,157
22,707
Kentucky
The event:
P500 starting down a steep hill, an easy transition across it near the top, then deep ruts to the bottom.
Driver runs the transition, but ends up pinched in the right hand rut with the front wheels turned hard passenger. Right front looks further open to the right than the left.
Buggy would not move forward or back, front wheels won't move left or right, driver (strong sum b****!) perhaps muscles the wheel too hard, dunno. No luck. Passenger exits the buggy; buggy then can move enough to move tires to get un-pinched and proceed down the hill.
Symptoms:
Shortly thereafter, driver notices steering slop and perhaps a new noise from the machine. Right front is found to be definitely out to the right and there is extra play in the steering, and perhaps a bit of a notchy feel. Certainly the steering no longer feels the same as my 520, as it did before.
Pictures, steering wheel centered:
20230821 170009
20230822 100811
Thoughts? All I've done thus far is wash it.
NTCPrezJB
NTCPrezJB
President of #NTC
100,500
898,123
Canton, OH
Any of your EPS connections have slop? Or a bend to the mounting plate?
And of course check tie rods not that they commonly bent on the P5’s but certainly could have happened.
That’s the two places I’d start looking at least.
208,013
The event:
Symptoms:
Ball joints would account for the sloppy feel, check both sides. A slightly bent steering arm would account for the alignment on the right side. Well that would be the first things I would check. Good luck,
The Green Goat
The Green Goat
1,750
12,387
Ohio
1. tie rod. Impressive if you managed to bend one.
2. ball joint
3. broken tooth in the steering rack?
futzin
futzin
3,157
22,707
Kentucky
Everything seems to look normal to the naked eye (mine, anyway). Haven't jacked it up or pulled the tire yet. Gonna be a while before I can, unfortunately.
I took a short video of me working the steering wheel back and forth slightly with the key off. You can definitely feel the steering hitting detents at least once each direction; not smooth. In the video, I exaggerate it a bit to illustrate. I'll see if I can get the video up. Busy day today so we'll see.
So I seem to be dealing with two primary issues.
1. Find reason for wheel being out.
2. Find source of steering play.
Really appreciate the help guys! Thank you . . . keep it coming
futzin
futzin
3,157
22,707
Kentucky
The connections seem fine to me thus far. Mounting plate seems unaffected.
P
pappyo
593
2,377
Sorry for your delima.
Hard Hit stop?
That sinario Weakest spot is A-arm attachment to Frame. ( Done One ) P.IA.
Worst :sinario bent frame hope NOT That one.
Plus any of the below mentioned.
Slow easy bind stop </> "strong sob driver" applying 2 much mussel
Could Definitely cause excessive strain on steering components
Weakest area of the Steering-rack is </>"In at Tie-rod </> 51% being the problem. ( various reasons done a few P5 & P7 ) P.I.A. but not bad
Check for play/ slop
Wheels / Ball Joints / Steering Rack & All Steering Shafts / U-Joints & Splines
( EPS mounting plate if you have ) </> put a bolt or self tapping screw through & where the mounting plate attaches to Frame <> takes the play out & Prevents Movement.
After you found play/ slop
Separate Both " Outer Tierods at Spindle/wheel
Recheck all of the above for noise.
Good luck with the fix.
All is Good <> "No-One qot Hurt"<> Time & $$$$ only thing lost.
B3's Pictures look like<> Driver on tailgate for weight <> passenger driving may have ??
FYI : Humor
When my grandson became old enough ( 13yrs. ago) to ride ATV. N.Y. Certificate required. Went along with him & took the Honda sponsored Certification. Both Passed.
Now he is on <>Motor Cycle <> BMW <> Mustang
I'm on <>1cyl. SxS <> 4cyl. Hybrid's. & member of Sinor SOS club. ( OLDER <> SLOWER <> Smarter ) well on the last one "trying"
Jerryg
Jerryg
10,605
85,869
NEPA
The event:
Symptoms:
I don't see anything wrong with it.
Proxy image
