P500 Help With Diagnosis
158,553
Hopefully that and the steering knuckle are the issues. I'll bet there is a You Tube Vid of the process, You will probably need access to a ball joint removal tool ( $25.00 OR LESS AT HARBOR FREIGHT) and a press to install new ball joint.
The ball joints are a b!tch to get out...just sayin'.
TripleB
TripleB
11,932
101,258
Caryville, Tennessee
Ok, that tie rod ball joint is very easy to manipulate as well.
Is the new tie rod end easy to manipulate too? On the 1000, one of the ball joints is easy to manipulate even when it's brand new. I cant Remember if it's the upper or lower. The tie rod end ball joints on the 1000 are stiff when they are new.
futzin
futzin
3,245
23,369
Kentucky
Pic of it with two new tie rods.
No change.
20230829 185344
20230829 185312
If anything, it looks worse.
