P500 Help With Diagnosis
futzin
futzin
3,322
24,048
Kentucky
I think PrincessB has found the bent part.
Passenger side A-arm, bent at the ball joint mount.
520:
20230903 133320
500:
20230903 133355
Tried to get the pics as similar as possible...
futzin
futzin
3,322
24,048
Kentucky
I figure I have a couple of options.
1. Replace passenger upper A-arm, realign, then see if lower A-arm/mounts still an issue. Pretty sure there's a little wonkiness in possibly both the lower A-arm and it's mount(s) at the frame.
2. Upgrade to arched A-arms, giving me the option to adjust camber. Could install 28" tires at some point as well.
Thoughts?
208,029
Thoughts?
Unless your up graded A-Arms come with rubber insulated bushings, get used to changing bushings.
NTCPrezJB
NTCPrezJB
President of #NTC
101,966
910,883
Canton, OH
Thoughts?
3…run it and limit pavement to limit tire wear
5,093
22,896
This is what I'd do. If the toe-in is correct and both wheels are cambered 'about' the same, I'd run it. To check camber, just put a level on each tire vertically, measure the inward/outward tilt at the 'gapped' end of the level (top or bottom). Tire bulge is irrelevant as long as both are measured the same way.
Like this but measure the gap to a bubble level instead of a string.
1693844981265
The Green Goat
The Green Goat
1,812
12,970
Ohio
I figure I have only one option:
1. Upgrade to arched A-arms, giving me the option to adjust camber. Could install 28" tires at some point as well.
Thoughts?
I mean, you're not giving me much choice here, but I see nothing wrong with this. That's what I would do.
futzin
futzin
3,322
24,048
Kentucky
Camber is off badly on passenger wheel.
I'll not be driving it as it is...
NTCPrezJB
NTCPrezJB
President of #NTC
101,966
910,883
Canton, OH
What am I missing?
Why would I not, at a minimum, replace the bent upper A-arm?
You can probably see the bend in the A arm better than I can in the pictures. I can see the off camber wheel in the pic but I don’t see the bend in the arm. If I did, I would tell you to replace it.
P
pappyo
593
2,380
Queen B has you Barking at the right Damage.
Fix it right & complete
Straighten frame A-Arm brackets or have done if it is not your skill level.
Or Pay in Tires.
Since you NEED <> A-Arms <> Arched is the <> "Only way to go".
Kinda like get to getting Arched at <> 1/2 price.
Its only <>> Time & $$$$
