P1000 2016 P1 Piston and Ring replacement
Todd627
Todd627
56,456
616,594
MI
Well my P1 has been at the shop for two months, which is fine by me. I don't have to walk by it and get disgusted every time I'm in my shop. Did call, intake valves very wallowed out. New head is on the way. At 4,560 miles. I recommend never buying anything first year out.
That sucks Smitty.
DRZRon1
DRZRon1
867
2,816
PA
I smell bulls***, POIDH on the wallowing, really? - the other member on here has pistons out and goin back in - in a couple of hours - no cases to split, something is amiss here
208,020
2016 P1versus the later models.
Reactions: Backwoods and ChadD
DRZRon1
DRZRon1
867
2,816
PA
Well, yabutt, why would they make such a big change in an engine? I mean it's a 1000 cc twin with a DCT transmission. Disassembly shouldn't be all that different. The Talon has basically the same engine - pull head, remove oil pan, remove rod caps, push pistons out the top.
But the Japanese have done stranger things. 😏
is this fixed yet?
part numbers for the crankcase sets are the same for a '16, '17, '18, etc.......
no mechanic - but, if they are not honing/sleeving/nickasiling whatever the bores and just swapping pistons and rings, it looks like a very very long couple of hour job - as CID said - take all the crap off to get to the head, remove head, drop skid\oil pan, undo piston rods and push up and out- push new ones back in, bolt up and put all the crap back on
not sure what carbon deposits means - from my limited experience it could just be loaded up a little from a bad valve seal, etc. - they all have carbon on the top - thats good - its been firing
yes they have to split the cases if they are replacing the cylinder "block"/ crankcase halve(s) or sending out for repairs - whole bunch of extra hours to remove engine and take apart and put back together
if its eating oil, someone providing the bill to you has data\readings showing its the bore out, rings out, etc. of spec.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I'm very sorry for your situation. If I remember right there was a service bulletin about the clamps on the intake boots not being clamped correctly. I never took mine back to the dealer, but I remember Hondatech recommending to put a 10mm allen wrench to check the gap. I checked mine and it seemed to be ok. Not that it helps any but just curious if it might have been sucking dirt after the filter?
Reactions: Smitty335 and ChadD
208,020
Yep, that was early on.
Reactions: ChadD
