P1000 2017 hard starting
K
Kwb
12
29
Edmonton
Replaced computer fuel pump and spark plugs battery injectors are working. So turn key on I can hear fuel pump sometimes injectors work engine cranks fine. I found out that if I turn key on with headlights on injectors always work but still won’t start fuel is clean high test.
Reactions: Lady01 and TxDoc
HBarlow
HBarlow
1,614
5,997
Daniels, WV
Poor starting and rough idle in a machine that is not driven daily and is probably subjected to sitting unused for long periods is most likely caused by bad gas, deposits in fuel and injector lines, and dirty injector tips.
107,282
☝️ ☝️☝️THIS☝️☝️☝️
Just Delt with the same $hit with one of my snowmobiles. bad gas that just sat from last winter jacked up a fuel pump and the vacuum hose barb for it. GD ethanol laced crap! And this was premium. after taking it out compared to the new gas, it didnt smell the same as the new stuff
also @Kwb of your machine…
Pics Or It Didnt Happen!!
K
Kwb
12
29
Edmonton
☝️ ☝️☝️THIS☝️☝️☝️
Sorry has new fuel and tank is clean
107,282
100% new, and all old stuff was siphoned out? Or is it mixd? did u check the screen in the tank and replace the fuel filter?
check you Injector wires closely as well. They've been known to be an issue
107,282
Since we havent seen any pics or any info about your machine since u didnt do the intro thread.
how many miles are on it and what type of riding do u do?
K
Kwb
12
29
Edmonton
8CE3CE21 78EC 4BCA 937B 5A7CC19C1063MileageE01F3713 512B 402A 8F71 E82D0C05AFEB
Rayger143
Rayger143
2,741
23,737
Winfield, BC Canada
4300 km is apprx 2700 miles. I run marked premium fuel in all my toys and tools. It’s 91 octane with a purple dye. We call it purple gas. No road tax so it’s a little cheaper.
K
Kwb
12
29
Edmonton
Up here it’s farm fuel the dye is If your pulled over without farm plates the police can tell your running purple gas illegally
Reactions: Lady01
HBarlow
HBarlow
1,614
5,997
Daniels, WV
If you start out with everything cleaned up and starting and running normal fill the tank with any ordinary pump gas and add the prescribed amount of Stabil which you can buy at Walmart, auto parts stores, and truck stops.
Sta Bil STA-BIL Fuel Stabiliser - Home is an old, proven, and dependable product that prevents stored fuel from turning bad and fouling your tank, lines, and injectors.
K
Kwb
12
29
Edmonton
Fuel is fresh I have stabilizer but sxs isn’t sitting long enough try to get out every weekend
