P1000 2017 Honda Pioneer 1000-5 limited edition?
Camp
17
Saint George Utah
First off this is probably my first post on the forum. I have been here a lot learning a ton from everybody else so thank you.
I have searched and searched and searched for days and this is probably been covered before but I’m tired of searching so here it goes.
I own a 2017 Honda pioneer 1000–5 limited edition. After reading many posts, I decided to get bigger tires and go with the tusk terrabite on a 14 inch rim. 30x10x14. To do this I read I needed to install super ATV a arms in the front. I purchased those and started to install when I started reading about issues with the axle on the Limited edition, and other problems with the ball joints of the limited edition. I ordered the HD ball joints after my failed attempt to swap the original over to the new a arms.
My question…. Will I have any issues running with the original axle? Is there any other issues that I’m missing that I might run into?
The picture is so you know it happened. Haha
B7D0B983 5FCB 4B6A 9031 3D6119E73DFC
105,367
As long as you dont do any kind of lift, your stock axels and everything else will be fine.
But one thing. If you went with 30’s should have got the rear arms as well for many reasons, cuz im surprised you havent complained about the rear rubbing and your camber in the rear that is non adjustable with your stock arms
