P700m2 2017 Honda Pioneer 700-2 Deluxe Camo
JeffEvans
JeffEvans
64
106
Arlington, TN
After a long wait (December 4th), I finally got my 700 in! Really excited to get started upgrading! I ordered a ton of upgrades before I actually got the SXS in...lol!
I've done a lot of reading on here so thanks to everyone who post here! I'm going to post all my upgrades along with pictures and notes for futures readers!
I bought it with a top, hard coat front windshield and rear panel. So, I'll be carrying it back to the dealer because they installed just an optic front windshield and the rear panel is different for the 2017 than the previous models (first learning curve).
To follow suit...here's the picture before any upgrades! A0b93226a3f1474b02cf53ca20b9e094
JeffEvans
JeffEvans
64
106
Arlington, TN
Here they are laid out...
- Front and Rear Light bars
- LED pods for inside, bed, and underneath
- Switches for everything
- Superwinch 4500-S
- EMP front and rear bumper
- Mudbuster front and rear flaps
- PDM 60
Few other small stuff...I'll post as I add more.
E083d11f4729e4451068060ac6a0da05
Ems-Cam
Ems-Cam
252
336
Alberta
That looks very thorough. What I suggest along with that is a tube of Di-electric grease and some star washers. All your grounds to the frame, use both. All connections, add some grease. This will displace the water and prevent corrosion. Are you looking at the winch on top of the bumper or in the bumper? Myself I went inside the bumper, I wanted it somewhat out of the way.
JeffEvans
JeffEvans
64
106
Arlington, TN
Definitely on the grease and star washers...but thanks for the heads up! I don't want to miss out on anything I should do...lol! Will save a lot of headache down the road.
For the winch...I was thinking on top, but will prolly make that decision as I get closer to that install. Was thinking top only because it would be easier to get to if I needed to use it. Have you had to use yours yet?
Reactions: sharp
JeffEvans
JeffEvans
64
106
Arlington, TN
Starting running all the wiring!
- Switch Plate from Mystic template 80a0f16a48ba2f108e2edb0e0480e161Fdd7089f24ab3dc0d66e5cb39ef56edf6d1d06b8f4d98c41fd42a9ef942a10a6
Reactions: sharp and Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I also mounted mine down low. Reason being, you have more options on what to tie to and pull from with your winch low and still have an upward angle on the cable, therefore the winch pulls you up and out of mud or other obstacles rather than down into them.
That make any sense?
Ems-Cam
Ems-Cam
252
336
Alberta
I think the top spot is where my light bar will go. Thoughts on the cheaper ones from amazon vs the rigid ones?
Reactions: sharp
321,218
Nice looking accessory table you have. Love the plan of attack on electrical looks good. Welcome to the forum
Reactions: sharp and Eltobgi
JeffEvans
JeffEvans
64
106
Arlington, TN
Like the thought process! You might have just swayed my mind to mounting underneath! Thanks!
JeffEvans
JeffEvans
64
106
Arlington, TN
Forgive my ignorance. What is the "Ground Trigger Switch"?
I have two triggers...one is the ignition trigger that turns on all accessories when the ignition is turned on. The second...the ground trigger...allows accessories (low power, dome light, bed light, and hazard lights) to be powered without the ignition turned on.
I am using the PDM 60 that allows circuits to programmed with either trigger or both.
