P700 2017 pioneer 700-4 dies after 20 minutes
Billk
11
10
Pierce, Idaho
My 700 dies after riding for about 20 to 30 minutes. I've replaced the spark plug, fuel pump, fuel injector and ecm. I cleaned the throttle body. I contacted the dealership and they suggested adjusting the valves, which I had them do. They thought that would fix the problem, no luck. It runs fine, then just dies, after 20 minutes or so it will start back up and run for about 20 more minutes. Any ideas?
Scrappapotamus
The Scrappapotamus
384
1,915
Midway KY
  3. Talon R
  4. Talon R LV
Have you checked the fuel filter and fuel system vents?
Reactions: Remington
Billk
11
10
Pierce, Idaho
From what I understand, the fuel filter is locted on the fuel,pump, I installed a new oem pump and it didn't work
Scrappapotamus
The Scrappapotamus
384
1,915
Midway KY
  3. Talon R
  4. Talon R LV
If it funs fine and dies, I would think you have a filter issue or a vent or fuel cap not venting. Can't think it would be electrical considering how it is behaving over and over. I' have seen the little vent hole in a fuel cap cause this. If this doesn't fix it, find the timer that keeps shutting it off and reset it? Have you taken the tank off and cleaned it?
Reactions: futzin
104,950
Any codes on the dash when this happens?
Any pics of the rig? POIDH
How many miles
Billk
11
10
Pierce, Idaho
How many miles
Nothing on the dash, no check engine light, nothing. It has 12000 mile on it. I change the oil every 600 miles with new oil filter, clean air filter. I've talked to the service department where I bought if and they seem stumped as well. They told me to run it till it dies. Pull the ecm and put it in the freezer for 5 to 10 minutes then put it back on and see if it starts, I did and it did, put in a new ecm and no luck
  • Wow
Billk
11
10
Pierce, Idaho
When I installed the new fuel pump, everything looked good. The vent hose was clean, no obstructions, tank looked clean. I was thinking maybe someone put a rag in there to mess with me, but I didn't see anything
Billk
11
10
Pierce, Idaho
How many miles
20231109 133828 20231109 133809 20231109 133746
104,950
Never heard of that before? Sounds like there fishin
Does it start rough or smooth?
And when you drive it is it smooth before it dies?
Also stupid question I know but we had this same issue with another P7 and it was this. Do u have a fresh air filter in?
Billk
11
10
Pierce, Idaho
It starts up fine runs smooth until it dies, then it takes about 20 to 30 minutes to re start. I have 4 different air filters and change them out about every 300 miles, clean and oiled
Glock21user
Glock21user
" Nothing succeeds like excess "
1,820
9,056
Livingston county, Mi.
Check all grounds and make sure the temp under the seat isn't getting too hot.
Good idea above about the ECU. I have done that before on older jeeps with the Ford ign module.
Reactions: Remington and Billk
Slackjaw
Slackjaw
277
452
Durham NC
Pop it in neutral immediately before it fully dies. If it stays running then that gives you a path to follow. (Not fuel related).
Reactions: Jerryg
104,950
Found the problem, a failing stator, replaced and runs again
Wow! Good job on the find.
Do u have too many accessories hooked up directly to the main battery?
Reactions: GovtMule
