P700 2023 Pioneer Deluxe 700-4 flashing power steering light
infyx
infyx
62
105
Maine
Hey Guys,
Ordered a roof and windshield from dealer - while I wait for those to come in I am looking around but plan on having them look since it should be a warranty issue.
However, I notice that starting the machine the light flashes twice every second or so. Repeat.
I have checked the battery itself, all the grounds that I could see/find - all are tight.
Is there anything else I can look at to save myself the hassle of the dealer looking and time away from machine?
Thanks everyone! Already bought way too much stuff from the store here but excited to get it all in.
Regards,
Matt
Reactions: Buggyman
HondaTech
These newer models use CAN codes for diagnostics. There is no code 2, the lowest number is 11.
Sure your not seeing the seat belt light blink? Those will flash until the drivers seat belt is buckled.
Reactions: Buggyman
HondaTech
I'll have to look more into the diagnostic codes and how they flash codes. Usually that would be code 2, but there isn't any code 2 on 2023 models.
HondaTech
The only code that will make the indicator blink instead of illuminating solid is
C0608-00 Angle Sensor Abnormal Signal
That's all I can come up with atm, all other codes will illuminate the indicator light and the blink pattern is the same as all other codes; Long= 10 Short=1
104,959
Guess I am having a dealer look at it.
thank you for looking into it!
Welcome From the Putrid Swamp Run Michigan!
Got pics of your rig? Kind of a rquirement for FNG’s newbies.
Pics Or It Didnt Happen!
infyx
infyx
62
105
Maine
Here ya go! I don’t have any good pics yet. Hopefully this weekend
360A9F36 36B5 4CC9 B5DD 27DAA4667180
infyx
infyx
62
105
Maine
So Honda dealer has it now. They called me and said the code is that the power steering is getting too much voltage.
said it could be the harness or something electrical. Guess I’ll wait to see what they find.
infyx
infyx
62
105
Maine
Update: Got a call from Honda dealer. Apparently the power steering unit needed to be 'updated' or 'recalibrated'.
They had to call Honda to get the proper process to do this.
So anyone with a 2023 with a flashing light, could be this.
HondaTech
We can set the rack and vehicle centering with a procedure in the manual. Unless it's something besides that, I'm not sure what their referring to.
infyx
infyx
62
105
Maine
So the document they gave me just says:
FOUND EPS SYSTEM NEEDED TO BE REPROGRAMMED, PERFORMED REPROGRAM PROCEDURE AND RETESTED
So maybe its the same thing but the steps in the manual did not work for them - there was "other" steps he said they had to get from Honda.
