P1000 2017 Wiper motor on a 2023
CJQuig
CJQuig
69
199
St Johns, Nl, Canada
will the electrical connections match the 2023? It’s a new machine, not fuse box installed, yet…
IMG 3252 IMG 3253
Reactions: JenElio and TxDoc
CJQuig
CJQuig
69
199
What type of fuse box, oem or aftermarket?
I don't have the fuse box yet, trying to confirm all I need before spending more cash... I would be lost without the support from this group, Ill probably go with the OEM, I hopefully won't make any mistakes...
Reactions: ChadD
NorthernJoe
NorthernJoe
327
1,272
Northern Ontario
View attachment 411573 View attachment 411574
I have a '22 trail, I just went out and looked I have that same plug on my wiper motor. You should have a harness that fits that white plug and goes down to the Honda accessory fuse block
This is what it looks like on the fuse block The additional black and red wires go to the washer pump
IMG 9966
CJQuig
CJQuig
69
199
ok then, you guys are great. I'll save this for later and fill you in when it gets done.
63,988
I don't have that white connector. But I can source it with a few more pics.
As for wiring it ip. I'm still trying to figure it out. It's hard without having the motor in hand. Lol.
NorthernJoe
NorthernJoe
327
1,272
Northern Ontario
Richard,
How can I help you with that?
Reactions: ChadD
NorthernJoe
NorthernJoe
327
1,272
Northern Ontario
I just went out to confirm the wiring on the white wiper motor connector. Here is what I found,
Black = ground
Red = +12 volt on from relay
Yellow = key-on power to the park enable contact
Green = +12 volt when the wiper is not in the home position, connected to the relay coil to keep the motor running
until it reaches the home position.
If you are building your own wiper control circuit, don't forget to add a 1N4007 diode to keep the contacts from frying
I hope this helps
Joe
Reactions: ChadD and Remington
63,988
Black = ground
I hope this helps
Joe
I think this is what I needed to figure out.
Thanks.
Reactions: ChadD
dweber23tr
149
491
Minnesota
the diagram that Ohanacreek drew shows a switched ground? were they wired that way in 2017
I can't say for sure but in my post there is another post referenced that was created in 2016 so I would be inclined to think so
Reactions: ChadD
NorthernJoe
NorthernJoe
327
1,272
Northern Ontario
Black = ground
I hope this helps
Joe
IMG 0042 2
EDIT I missed the black wire from the wiper motor to ground
This is how my wiper motor is wired I did not trace how Honda wired the washer motor If you are building your own control you could power the washer switch from the output of the wiper circuit or power both the wiper and washer with the washer switch I have read that you should add a diode but not sure where it should go
Reactions: ChadD
CJQuig
CJQuig
69
199
Just ordered fuse box, mount, and wiring from Honda.
Reactions: ChadD
CJQuig
CJQuig
69
199
IMG 3266 IMG 3264 IMG 3263
CJQuig
CJQuig
69
199
I’m just aiming for the wiper. No washer.
CJQuig
CJQuig
69
199
Ok, I think I found what I require. I purchased the window and the wiper that was in the first post. The wiper kit contains a wire harness that I did not get from original own, but have reached out...
IMG 3271
IMG 3270
Reactions: ChadD
NorthernJoe
NorthernJoe
327
1,272
Northern Ontario
View attachment 411790View attachment 411791
That harness will connect to the wiper motor, but will not plug into the 2022 and newer Honda accessory fuse box HondaSxS can make you a pigtail for the fuse box end
