2021 talon x, things i have found wrong.
Sandsurfer
Sandsurfer
NM
This site has been a real asset for knowledge on this talon, so firstly thank you all for that.
I have 9 miles on my talon lol. So far my riding season has been non existent but hopefully that will change soon. I have been through this honda top to slowly bottom and here is my list of things that I have found done wrong.
-2 bolts on skid plate that were loose and I found were stripped.
- ground point under seat all wires are loose.
- I found a whole bunch of leftover bolts and screws that were caught in the upper side of the skid plate. (Funny story there, a friend also with a 21 talon x found a torque wrench on top of his skid plate from original assembly).
-steering wheel canted to the left about 15 degrees. It does not pull to one side at all but yet to drive straight, the wheel is turned left.
-bits of the wire feed weld where a weld was started and then must have abruptly stopped. The welds are complete where needed, but there is wire left unwelded attached to the frame in one spot. Overall the welds on the frame are sub par for what honda should be putting out.
That's it so far, next will be to check fluids. I am fairly disappointed in the quality control overall.
106,132
This is nothing new since 20’ unfortunately. All manufactures have these issues. You can thank the Scamdemic. Search this up top and youll see Theres been a few threads on this.
One things for certain, you need to get that thing out and ride it!
Only 9 miles! 🤨
Did you take any pics of this stuff you found?
Sandsurfer
Sandsurfer
NM
I did not know that was common knowledge. I took a couple photos of some poorly fitted body trim parts that I corrected shortly after. I took a photo of the ground before I tightened that. The ground really makes me angry because there is no excuse for that and it could have really caused me trouble. Today I bought new hardware for the skid plate so that's been fixed. I still have to adjust the steering wheel. I'm not sure yet what's involved with that.
906UP
906UP
13,052
121,736
da Yoop
......... I still have to adjust the steering wheel. I'm not sure yet what's involved with that.
I had to do the same on my 2016 P5 and 2019 T1Kx, it's nothing new and about a 5 min fix if you're slow about doing it. Pop the center cap, remove nut, give the wheel a jerk, align and reassemble, done
PaulF
PaulF
1,462
4,810
There have been a lot of Talons delivered with the steering rack not centered, the wheel not installed centered to the rack and/or the toe not set so don't just pop the wheel and center it or adjust the tie rods to center it.
Follow this thread to properly verify that the rack is centered (and adjust if necessary), then center the wheel to the rack if necessary, then adjust the toe if necessary...
5,038
22,544
OK thanks Paul I will try to follow those instructions.
The link in my sig will take you to some basic Talon information if you haven’t seen it. It’s also a sticky in the General Talon 1000 Discussion forum making it easier to find. Check your sub trans fluid level, both of mine were delivered low (8 and 10 oz. of 35 oz. low IIRC :mad: ). I don’t have my manual handy so I’m not positive on the full capacity. 😊
Enigma
Enigma
East Tennessee Mudder
366
838
Rocky Top
Great information. Thanks Sandsurfer for the extra work for club members. One question - when you retightened any bolts, did you happen to go to the Honda Talon Service Manual and tighten them to the Honda manual torque requirements? I just thought this might be a hard data point to indicate how much the botls were loose. Just a thought.
Sandsurfer
Sandsurfer
NM
I did not. With the ground I tightened until no movement of said ground wire connections. With the skid plate I put on a drop of blue lock tite and tightened just to the point of no play between the skid plate and the metal attachment point that it is held against. I am ordering a service manual tonight though.
Reactions: Smitty335 and CID
5,038
22,544
The service manual is money well spent and not all that expensive.
Hometeam
Hometeam
939
3,697
Normal, IL
If you become a supporting member it gives you access to more of the forum and with that access is manuals for any of the machines, that you can download!! Not pressuring you at all but the membership is cheaper than the cost of what you get with it!! Hope that helps!)
Jhall244
37
128
NE ohio
Owners manual or actual Honda service manual?
