2020 Talon 1000r Hard to get into Low
T
Talon_2020
North Carolina
I have been having problems with my talon not wanting to go into low good, sometimes it will and other times it Won't I've tried adjusting the shift Cable and that helped some Was just gonna see if there is anything else I can try
5,038
22,546
If there's any way you can warm it up before using Low, it'll work better. Mine has been hard to shift a couple of times but only when 'cold' - including an 80* day at the trail head. It also helps to shift firmly, don't p u s s y foot and having your foot off the brake helps sometimes. Shifting while barely moving might help the shift dogs line up. More details in the link in my sig line.
NTCPrezJB
NTCPrezJB
President of #NTC
100,855
900,912
Canton, OH
There are a couple of peeps selling Talon shift gates. @PaulF is one of them. It seems the stock one prevents positive engagement.
906UP
906UP
13,052
121,738
da Yoop
I can vouch for this, I had the dreaded low gear grind a couple times while at RRB in the Spring. Since installing the @PaulF shift gate I haven't had it since.
Sheetmetalfab
Sheetmetalfab
2,017
12,312
Alaska
Pauls shift plate is the only one that holds it in low.
The rest of the aftermarket ones have too wide of a notch.
Mudd-man1000
Mudd-man1000
39
67
Morgan co
Get it fixed ASAP My low went out and have been waiting on parts since July . Honda loves to sell new units but don’t worry about having parts to warranty them with ! And no it’s not because of covid last winter it took 3 months to get an axel
TalonR65
TalonR65
34
47
Tucson AZ
Drain sub transmission and fill with light weight shock proof made by redline. Way better lubricant than engine oil . Change mine when new now have 2200 miles. Smooth shifting
hondabob
1,162
4,538
Prescott Valley, AZ
I like to use low to load it on my trailer. Like CID says use drive to get it rolling slightly then a quick shift into low works great for me. I don't like to force it into low. A better oil helps. I use the Honda 10w40 synethic blend with moly in both of my Talons. When in any gear always make sure the shift lever will wiggle back and forth verifying it is fully into gear. If the shift lever is loaded forward in the shift gate its not fully in gear. My 2019 Talon with over 15,000 miles shifts into low better then my 2020 Talon with around 2,600 miles.
Reactions: TripleB and CID
Rednick69
Rednick69
154
1,260
White Hall, AR.
@highpocket74 sells one too. It's what I bought and seemed to fix my "getting into low" issues.
HondaTech
The axle issue last winter was due to a new part number superseding the old. Covid has and will f*** stuff hp for awhile. If your dealer was good they could get that gear faster.
PaulF
PaulF
1,462
4,810
Paul could you link me as well? I’d like to see what it looks like and pricing/options.
Info, pics and pricing here...
PM me your paypal account email and I will get one to you ASAP.
SLOWPOKE693
SLOWPOKE693
1,615
6,137
Somewhere in Texas
This is no BS.
