P1000 2022 1000-5 stinger, fuse box and pink wire?
T
Troyp
6
Traverse City, .mi
Hello! I ordered the club stores version of the stinger relay to hook up to my pink unbundled key on hot wire, the club blog to look that to and a club fuse box. I am not adding a second battery at this time. And advice on what to hook where on this project would be GREATLY APPRECIATED! Thanks!
63,710
COOL. about as simple as it can be.
6 gauge wire: Battery positive --> relay --> fuse box positive
6 gauge wire: fuse box ground bus --> main battery ground
Relay small post (18g wire): goes to any ground. You can run it to the fuse box negative bus.
The other relay small post (18g wire): needs the key-on hot.
AND.. you done!
106,223
Welcome fellow Michigander at the clutches of Big Gretch!
Got some pics of your rig?
POIDH
Scoop
Scoop
4,252
15,930
  3. Talon R LV
Welcome from another MI resident!
You're going through the trouble of adding a Stinger and a fuse panel for accessories, so you might as well get the 2nd battery and isolator now. Otherwise, will likely have to spend money buying different cables to get everything wired up when you add those later.
Just my $0.02. I hate having to undo and re-do electrical stuff once it is installed and working.
T
Troyp
6
Traverse City, .mi
AND.. you done!
Thanks!!!! I can do that!!
