P1000 Aux battery and stinger
K
kyrider1000
67
217
Kentucky
Ok so my question is this , I have installed a true dual system and stinger . But , I still have to obviously turn on the key to listen to the sound system if im just stopped somewhere enjoying a adult beverage . When I turn on my key I get this tone or noise like sound , I'm assuming it's probably the fuel pump . Question is , will it hurt anything for my key to be on for a period on time ? 2nd question is , will me having my key on run my main battery down ? . Thought that was the reason for the true dual system with stinger .
Ride em safe ✌️
dweber23tr
148
473
Minnesota
That is because your stinger us powered by key on power, i.e. the only way your stinger works with the aux battery is when you key is turned on. You would need to wire it with a toggle switch instead to get it off of key on power directly to run your stuff without the key on.
Reactions: Remington
Scoop
Scoop
4,257
15,963
  3. Talon R LV
This is what you seek:
Screenshot 20230603 081722 DuckDuckGo
Hillbillytnt
Hillbillytnt
520
1,919
Ky
For most the purpose of the isolated second battery is to prevent the winch from drawing down the main to the point it won’t run the stuff it needs to run. Which can happen even with the machine running if your working that winch hard. You need to put the stinger on a toggle or a maintained on/off/on switch. The club store sells a good one. The wiring diag is rt there too. That gives you the best of both and the option to turn the whole thing off
Scoop
Scoop
4,257
15,963
  3. Talon R LV
Provided that you have all your accessories and winch powered by your AUX battery, you don't need a toggle to keep the winch or accessories from drawing down your AUX battery if you have an isolator. That's the entire point of the isolator. The DPDT switch simply allows you to run anything connected to the AUX battery (beyond the Stinger or other continuous duty relay) without turning the key on. This avoids energizing anything OEM (from the main battery) while being able to run all your accessories.
