P1000m5 2022 Grinch gets new grill, badlands 5500 and Bolt on shackle mounts
A
ADVBUM
64
244
Arkansas
Grinch original bumper
Start. I got a take off bumper from craigslist. A badlands long drum APEX 5500 winch at the Harbor freight Christmas sale. Kfi mounting plate. Bolt on shacke mounts.
The shackle mounts inside plate needed to be trimmed down about 3/16 on each side.
20240107 1238441
The backing plate will fit perfect.
20240107 1239191
One of the bolts needed to be cut down. Put the bolt through both plates next to the nut and cut about 1/4 above nut.
20240107 1605451
The KFI mount would not work with the Badlands long drum apex 5500. The holes were 1/8 inch off. I had to cut the top of the KFI bracket down by 3/16 and wheeled out the bottom of the two upper bolt holes of the KFI bracket. I then opened / widened the KFI bracket using a car jack just enough so the winch would fit in and holes would line up. I test fit the winch in the bracket and then test fit bracket to the machine before installing.
I think it all turned out solid.
20240108 1305541
TxDoc
TxDoc
1,632
5,649
TEXAS 🇨🇱
photos.app.goo.gl
The shackle mounts inside plate needed to be trimmed down about 3/16 on each side.View attachment 414053
The KFI mount would not work with the Badlands long drum apex 5500. The holes were 1/8 inch off. I had to cut the top of the KFI backet down by 3/16 and wheeled out the bottom of the two upper bolt holes of the KFI bracket. I then opened / widened the KFI bracket using a car jack just enough so the winch would fit in and holes would line up. I test fit the winch in the bracket and then test fit bracket to the machine before installing.
Looks great ARMike
I think I have the same mounts E62e36e3a5f517f13f0debd10644a7f2
Sent from my motorola edge plus 2023 using Tapatalk
105,915
I like it! Good job.
Was the neon style green on purpose or was the color match hard to get?
Reactions: TxDoc
105,915
Reactions: RoyLee89 and TxDoc
