P500 26” Tire Overall Width
Stevea83
12
NY
Hello all, first time poster here but I’ve been reading up. I have a 23 P500, I’m looking to upgrade to 26” tires to gain a little more ground clearance in the wooded areas I ride in. I’ve been doing my research here but still trying to find out how wide I would be overall with this setup. I’m assuming it would put me somewhere around 53”. Thanks in advance, Steve
ITP Delta
12x7 Wheels with 5+2 offset (front and rear)
Bear Claws
26x9-12 in the front
26x11-12 in the rear
Reactions: pappyo
106,245
Welcome from Michigan!
Youve been reading up eh?
So you know to do an intro and post pics of your ride? 🤣
Its rule #4 Pics Or It Didnt Happen!
Goof lick with the tide hight thing. Every machine is different. But @trigger can give u a little insite to the P5 on this. But u really wont k ow till you experiment with it yourself. Till then….POIDH!
Reactions: trigger and pappyo
Tom_C
Tom_C
141
446
Virginia, USA
Only comment, or 2 comments, I have is 1) my 27's turned out to be around 26ish. I have Wanda tires that came on the ride when I bought it. Also, 2) as @trigger recommended, the machine is already tippy, so you may want to add spacers, too. I added 1" on all 4, so the width is around 53" now, give or take.
Stevea83
12
NY
My apologies, here is a pic. @TomC what size tires are you running?
IMG 3948
Tom_C
Tom_C
141
446
Virginia, USA
11 and 9, same as what you want to get, but mine are 27s. I measured them the other day and saw they are about 26ish tall. Maybe because they've warn down a bit, not sure. I have a 2015 500 and the 27s fit fine, no rubbing and plenty of room. I *assume* the 2023 will be the same.
ETA: Oh, I don't know the stock tires, but if they are the same width (11 and 9) then it should be about the same width with the new tires, maybe a tad wider but not enough to worry about, unless you want to ride on limited width trails or have to fit a specific trailer or whatever.
P
pappyo
593
2,379
First - Welcome from Upstate Cenral N.Y.
Many good people & information to be found here on the Honda forum.
FYI : ( Do not let those that are more full of themselves scare or discourage you. ) Has happened in Past.
Red was the 1st. Color & all other colors followed.
NICE Rig.
Bear claw HTR 's Good All Purpose Tires -- for traction & ride comfort "Great choice"
27x9 ft.-- 27x11 rear-- on ITP 4x3 offset wheels "no spacers" measure 53-1/2 Wide.
Reactions: 1border4manu
106,245
Nice little buggy!
Yeah, you need some bigger tires.
My old P5 had 14’s same size all the way around. You can see them in my build im my sig. its the bumblebee build.
157,215
I think I was at 52 1/4" when I ran 9's up front and 11's in the back. Those were 26" BH 2.0's and were 26 1/2" actual.
Stevea83
12
NY
That width would work for me. I saw a couple posts that the Bear Claws were running smaller, someone posted the 27” were actually closer 26” so I don’t know if I should order the 26” or 27”
Tom_C
Tom_C
141
446
Virginia, USA
27!
Nah, whatever you want. I'm happy with the 27s on mine, but it came that way so I don't know any better. But, if you are wanting more clearance, then.....
Here is mine from back when I bought it, I don't have any recent pics. I have added 1" spacers all around.
500
266,334
ITP Delta
Bear Claws
If you use your OEM wheels you could probably stay around 51" wide or go with 6+1 offset in front, but options for that offset is slim pickins. I ran 26x9x12 all the way around OEM 12" wheels on my 2015 P500 and it was still 50 overall width.
157,215
It's starting to come back to me now...
never rode the stock tires, put 26's on when I got it home, 9's on front 11's in rear. Don't know what it measured but it was a death trap. Put 1" spacers on all 4 and that's what took me to 52 1/4". Way better!
Changed stock wheels to 5+2's with the same tires, that put me around 54".
Changed tires up front to run 11's on all 4, believe I was at 55 1/2". Tried running 1" spacers on front and 1.5 in back to give it even more stance but the front rubbed bad, bent my rock slider down when in reverse.
Switched out the A arms to forward arched and mounted 28x10's on the 5+2's, with 1" spacers in the rear and I'm around 56".
Keep in mind these numbers can vary on any given day. I always measure to the bulge of the tire on each side with a level and mark the concrete.
If you go up you have to go out otherwise it's capabilities are severely hindered and it's a pucker fest.
106,245
Here u go, assuming u didnt look it up.
My old P5.
14” ITP wheels, 27x8x14 tires all the way around and 1” spacers. For the life of me i cant remember the name of the tires? They did good tho.
58784904351  EC0E2310 560D 4FCC A089 01BB6C5BED43
58784902983  08F794F9 AEF9 4C9E A2DA 2E5566078B2C
266,334
