27" tires tight fit?!
Timmy
Timmy
370
751
Elkview, West Virginia
Let's get back on track of 27" tires....
I'd like to see more setups with 27x9r12 on all 4 with radials.
I ordered 4 27-9x12’s for mine with stock rims
D6FCE9EC C83F 4E28 9220 14D995252F52
Tbee
Tbee
DFW
I have 2018 P500 stock rims 9x12,27 front 11x12, 27 rear still fits thru 50" gates better ride. No rub no real power loss either. Tires are GREEN BALL DIRT COMANDERS. My nephew has a p5 2015 with mega mayham 28 14" rims little rub but very rough riding. I can do anything he can but i am not much for really deep mud.
Reactions: JsheII3
Timmy
Timmy
370
751
That sounds good. I am having trouble getting mine seated on the rims. I’ll post pictures when I get them on.
13,478
66,540
@Timmy are you removing the valve core while trying to inflate to seat the rims? It makes a HUGE restriction for air flow while trying to seat a bead.
Reactions: Gassygordo
Timmy
Timmy
370
751
Yes, I removed the valve core. Tires were banded together and smashed.
Timmy
Timmy
370
751
They are @ 28” inflated to 6-7psi.
FYI in your pic of the red 500 the tire tread is backwards. Swap your tires from left to right side. The tread swoops forward for more bite.
I still need to turn my right rear around . The other three are right now. My neighbor mounted these for me. LOL
jmcampbell54
292
628
Texas
Cool deal, I didn’t want to sound like a jerk but you’d get a ton more performance out of the tires.
160,097
28"? Are yours 9" wide too? No rub at full turn and suspension compression? Offset wheels or spacers? I thought I read some 28's rubbed on the P1k and you'd have to do the frame mod on the P5.
jmcampbell54
292
628
Texas
27x9x12 front
27x12x12 rear
5-2 offset beadlocks
They do rub at full lock and compression, I have not done frame mod yet.
Fronts measure out to 27.2ish inches
0a6a770a8c2eacc2ce4bb16f5625d1a3
Rear measure out to 28.5”
A9e81ac0efe101e4b52d83c4e9dbed88
So if you have the interco Super swamper tsl see the measurements above.
jwfirebird
jwfirebird
927
1,446
western ny
bighorns are expensive and heavy, terrible in real mud and snow too. there is a guy that had them in my group he had to backup and try again in 4wd, the can am i had just the stock crap during the summer 2wd one try on easy mud. we dont leave them, good snow tires like mud light, swamp lites something like that to ride snow
tim you using a ratchet strap to seat the bead?
