P700 2nd Accessory battery
N
Norndorf
12
12
Central PA
Would you need to wire a secondary battery into the relays of the main system? Or just run your accessories right from the secondary battery and they will always have power available to them? I am running LED light bar, rear LED lights, winch, hydraulic plow kit and then a radio. I have them all wired into a fuse block then to the secondary battery.
Mudwing
Mudwing
36,959
306,563
The Mud holes
Would you need to wire a secondary battery into the relays of the main system? No. Don’t do that. Or just run your accessories right from the secondary battery and they will always have power available to them? Yes. Do this. I am running LED light bar, rear LED lights, winch, hydraulic plow kit and then a radio. I have them all wired into a fuse block then to the secondary battery.
Dockman
Dockman
168
343
I simply removed oem battery and replaced with a marine deep cycle. Mounted bigger battery under drivers seat and ran new battery cables.
De307cfba7aa245fd2dec51cc1baa0fc
737e86f0c6c39bdead5813bd6f4d022d
158,686
Not a big deal for guys in the warmer states but those deep cycles aren't really made to be a starter battery. Used more for running accessories they usually have a lower CCA rating and might not have enough a** for starting in the cold.
Reactions: Backwoods
Hillbillytnt
Hillbillytnt
518
1,908
Ky
Acc to fuse block is fine. Winch to battery would be best with power for controls run through fuse block. I use the key on harness from the club and a stinger to control the fuse box so it is not live with key off.
Dockman
Dockman
168
343
800 CCA
