P700m4 700-4 on Ram 2500 Long Bed
N
Nampol
6
14
Las Vegas
She is barely fit! got about 1/2" left and right extra. Anyone done those "Riser" before? just need may be 15" extra front lift to be able to close the gate to tow my Travel Trailer without hit the Jack. Any better idea that is not going to break the bank? Thank you
20180817 173636 20180817 182234
208,135
View attachment 84466 View attachment 84467
Don't have a clue, but that's a bed full.:)
67,594
I used a hitch extension with my truck camper and enclosed trailer. Worked great.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Is removing the tailgate an option? That’s the cheapest thing I can think of
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yes possible but just too close at the edge. kinda worry if it slip off
Like @Gator said you can tie it in such a way that it won't budge. I'd run straps from the rear of the sxs to the front of the truck box, so they are pulling it forward. And use heavy straps too.
One time I had to put two sxs's on my trailer and my 700 was kinda hanging off the back like yours is in the picture. I tied it down then added a couple more straps for peace of mind. When I was done, 4 straps would have had to break simultaneously in order for the rig to move. I was pretty comfortable with that.
Anyway, when you tie down just as yourself these questions- if this strap breaks, what would happen? In order for the sxs to fall out the back what would have to fail? Basically identify the weak links and beef them up. Using 4 to 6 straps you could get that thing tied down so good it wouldn't come off if you rolled the truck!
Farmer
Farmer
2,850
16,380
Southern MO
A couple of longer planks, I.E. 2x12's, that run the length under the front and rear tires. That would allow for tailgate removal. Or....
Smaller golf cart wheels and tires for transport and a cordless impact gun?
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Come to think of it, my buddy hauls his 4 wheeler like that (tool box makes it hang out the back) and he has a net that attaches to the truck and goes across like a net tailgate. That might be what you need. I'll see if I can find a link
Reactions: Farmer and Gator
67,594
don't you lost like half of max load capability with that extension?
Yes you lose some for sure. Depending on which one you purchase.
hoghead76
hoghead76
1,161
6,204
oklahoma
You can change out the trailer jack to a swivel mount jack
if you have room between your tail gate and travel trailer
to make turns.
Farmer
Farmer
2,850
16,380
Southern MO
to make turns.
Good point! I avoid buying trailers that don't have the swivel jack. It all started when we were moving and some a-hole set my shiny tailgate on the jack handle and climbed in.
hoghead76
hoghead76
1,161
6,204
oklahoma
Been there help daughter move and her ahole husband droped tail gate toke out handle and rear camera
Bluesnipe
Bluesnipe
Hiddenite, North Carolina
If you can secure it well like that, loose the tailgate. Towing problem solved.
jmcampbell54
292
628
Texas
Dodge / RAM - DG Manufacturing. Tailgate Support Bars
10” version should put your tailgate up high enough not to hit the trailer/jack.
Reactions: Farmer
N
Nampol
6
14
Las Vegas
