700 Auto Backup Light Install Instructions!
63,516
This kit has 3 plug connectors.
- white 2 wire plug. This is for the light.
- black 3 wire dual plug splitter for the gear position switch by the eight rear tire.
- black 2 wire dual plug splitter for the ACC socket under the hood.
Start with the black splitter connector that has 3 pins.
Inside the wheel well of the rear passenger side you will see a few wires like shown. The one circled is the gear position plug. The connector with 3 pins will plug into this spot.
Unplug the OEM harness and plug this kit inline. Ensure both the male and female connectors click together.
20190312 082622 20190312 082708 20190208 144110
D446ea6111ac597ce694f1e1bd46fa9d
Next you will need to run the other black 2 pin split connector up to the front hood.
Note: white plug is shown. Your will be black.
Do so by following the main wire harness past the gas tank and along the frame and on up into the hood area.
Once to the hood area this split connector plugs into the back of the ACC socket (cigarette plug).
Ed1ce60735d393770f558cb02bf9e82341104a85962c66138c57921d082495a411ac1786dc05e5289ffa7e6d56125fe04fea98df245597fbda427b901a12a5391939138af50dfe48836d565f8300b465990623badf788c729ecef27e1aecf1ca2ba164f8f7e26eac3983793fd45fc71f1f667612489ec74115a0ea0047e5bf65
63,516
Running the light plug.
Next run the 2 wire plug up pillar B and across the roll bar to the back. Use the supplied clamp and clamp it to the roll bar. Connect the light and test the unit.
Zip tie all loose wires and you are done
9bfaf606a8d31c75e0b87730492f9b0646b91862bc386fc7aefc4c69e210d87f0364c79568cff6f49d6627c9881e59d97494c6f29ae795dbb829a1e67b4c49a0D60d580da16798900daa2c3cc93e522eF88afca20f807035471301368b339d09
Similar threads
