P700 Accessory panel
Srchamberlin
34
61
Hey guys
Is there a way to wire in a plate that would turn on and off with key that I could use to hook all extra ( new ) things added ?
I hooked my winch strait to battery but was wanting to add additional lights and Bluetooth system . Thought it would be nice to have a panel under good or somewhere I could just run everything from?
Thanks
Srchamberlin
34
61
Hey guys
I hooked my winch strait to battery but was wanting to add additional lights and Bluetooth system . Thought it would be nice to have a panel under hood or somewhere I could just run everything from?
Thanks
Mudwing
Mudwing
36,959
306,564
The Mud holes
Search switch panels on the forum. @mystic1219 sells a panel that will fit where the death label is. Use a fuse block from Amazon. Use relays if accessories are higher amp than switch is rated for. I don’t know how to link threads but there are plenty of discussions on here about it. Good choice of machine. The seven hunds are the best looking Pioneers!
Srchamberlin
34
61
Srchamberlin
34
61
Thanks I figured there was a way and a previous post with info.
I really like the 700.
Had a 660 rhino for years was a nice machine but wanted something new. Onlythingi wish the seating was easier to modify. My daughter has CP and wheelchair bound. On the Rhino I swapped stock seat out for a more molded bucket to help her sit better. Had to do some engineering with the honda bench seat. I could only add some bars with wheelchair parts to help her stay sitting up.
Thanks
