P500 Aftermarket wheels same size
BryanC
25
14
Are there any after market wheels same offset as factory? I do not want the tires sticking out from the fenders any. Thanks.
BryanC
25
14
Ok. Thanks.
How far do the tires stick out with a 5-2 offset? I will have 25-8 & 25-10 tires.
63,999
Here is the info.
Actual offset specs are not posted by Honda. But the actual rim size is printed on the wheel.
Here is what we measure them out to be.
Front 12x6 with a 4.5+1.5 offset.
Rear is 12x7.5 with a 6+1.5 offset.
63,999
So.. 1/2 inch on each side. + the extra tire widgth. Might be looking a 51" to 52" stance at max.
p500fan
p500fan
418
358
Sand Point, AK
I'm running 11" wide tires on the front. My overall width is a little under 54".
p500fan
p500fan
418
358
Sand Point, AK
I'm using 5+2 offset wheels from STI. You can find different offsets, but finding them with the proper hub size can be a pain.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
@p500fan it may have been a pain but it payed off because it looks great!
Reactions: p500fan
BryanC
25
14
P500fan - how is the steering with 11's on the front? How much mud is it throwing?
p500fan
p500fan
418
358
Sand Point, AK
Thanks bobbyhill! It steers wonderfully, BryanC. In fact, one of my students was driving it, & was convinced it had power steering. One hand is all you need for 95% percent of time. It does throw some mud, but not as bad as I was led to believe. My avatar is after my first ride. I buried it to the frame, & had to dig myself out. It (and I) needed a bath, but it wasn't any worse than the ATVs. In fact, it wasn't nearly as bad. I have the soft doors on it now, & I went on a short ride yesterday in the rain. there is a little mud caked on the bottom sealing gasket of the soft doors, & a little on the hard portion of the doors. Other than that, I can't see much. While driving in the rain, I did notice a small "fan" of spray coming of the front tires, but it was mostly being thrown forward (away from cab) at a 45 degree angle.
Mabe
Mabe
21
I put Sedona aluminum wheels with stock tires and the widest it is on front and back is 50 inches on my P5.
Reactions: rocmar and p500fan
63,999
@Mabe
Thats actually a good find. Good job locating those. Specs would keep it close to factory.
R SERIES WHEEL
The R-Series utility ATV and UTV wheels are manufactured from high-grade aluminum with a clean machined finish. These wheels are ultra strong and lightweight for many of the larger utility ATV and UTV quads of today.
  • Available in 12-inch sizes
  • High-grade aluminum with a machined finish
  • Caps Included
  • Part # - 570-1100
  • Size - 12x6
  • Lug - 4/110
  • Offset - 4+2
  • MSRP - $83
Mabe
Mabe
21
I bought them from a dealer in Utah, was 224.00 with lug nuts and free shipping, I really like them.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
And they look sharp too!!
Reactions: Mabe
