Auxiliary Lights
BigRiver
BigRiver
324
79
Installed a pair of auxiliary lights on my ride the other day. Went with the Rigid 10" double stack spot/flood combo up front and a small 60degree flood in the back.
I was hoping to install the light bar up front, but if I did, it would effectively become my front bumper….ah…No, not going there. I didn't like the position that Honda had mounted theirs up on the roof…why would you want to make a hole in the roof?
Came to the decision to mount on the upper part of the front cowl, just above the cover. No issue with drilling holes, good access to the wiring main frame and it's works for me.
Image1 7
Image2 2
Image3 1
Figured I needed a back up light to avoid the trees and things I don't want to back into. Hopefully I'll use it for loading up deer and hogs this season.
Image4 3
Image5 1
Image6 3
BigRiver
BigRiver
324
79
Haven't used it at night yet, I actually can only see some of the light and not the hood at all.
daberry
68
Kansas
I really like the position you chose for the front light. May not give quite the light as the roof top but like you said why cut the roof!?! Could you let us know how well they do at night?? Thanks, Dale
Yeah wish I'd thought about that before I committed to the roof.
BigRiver
BigRiver
324
79
Wes, you could always plug the holes if you ever want to move it.
My initial concern was hitting low tree branches and damaging the light.
It's raining tonight, but in the near future I'll get a few pic's of how the light works.
That would screw up my color code on my wiring diagram, I'm too OCD for that, too lazy to unhook everything to change the color of 1 wire and too hardheaded to change my mind. Even if your idea was better. The holes are sealed and I made them JUST big enough that I had to screw them in the roof.
