P1000 Back tires toed in after lift and spacers
Chunks21pioneer
6
I have a 2021 1000-5 and after I put the a arm kit, 3” lift, and wheel spacers from SATV on it made the back tires toe in pretty bad. Anyone else had this issue or know what it might be? Thanks in advance
JenElio
JenElio
65,863
614,187
Loxahatchee, florida
If you have the SATV a-arms you can adjust for toe.....
320,749
What @JenElio said. They don’t come preset to all the various setups. The wheels don’t stay straight through it’s compression/rebound so lift it’ll be way off and SATV is only relatively close by themselves.
SuperATV
SuperATV
1,254
8,757
Madison, IN
www.superatv.com
Yes. It's a pain!
It ain't that bad @Smitty335 ! 🤣 🤣 It ain't that fun though. Just takes a little patience.
But yeah, that's pretty normal after adding a lift. You'll need to adjust for the suspension change.
And always make sure you roll the machine out down the driveway before checking it out. The suspension needs to settle before checking those measurements. Toe and camber is always wonky right after you set it down on the ground after working on it.
