P500 Bear claw HTR 27’s
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Want to install 27x9 and 27x11 HTR on stock wheels on the little billy goat, wondering if anyone has done the same?
4C1666B7 915C 4383 98C4 0A34216A8083 EB4ADB18 4E85 4CBB A3E0 CCE391B64EAC
107,362
The stock rears on a P5 are wider than the Fonts dont forget so you might have an issue. If it was me as I did with my Old P5 and all my other rigs. If your going through all that trouble of un mounting and re mounting, I would ditch the steel wheels and get some nice new wheels same size all the way around. Do it once. You dont want to do it twice 😉
Robobrainiac
Robobrainiac
2,465
8,606
Wheels can be cheap. If you find a set you like on here you can open a chat window with these guys and they can give you a better deal on a set. I like these guys and have purchased a total of 4 sets from them. I have had good luck with these guys.
P
pappyo
593
2,380
26'x12's <> Kendra Bearclaw's HTR's <> on Aluminum Stock Yamaha Wheels on P500
Simular if not same as P500 steel wheels. <> worked good <> looks good.
Real nice Smooth Trail Tires <> decent in mud.
ITP HTR's 27x12's <> on after market Alum. 4/3 offset wheels.
decent trail ride <> Better in the Mud
Both good setup's <> both Radials <>
Anyone running bear claw htr 27’s on stock wheels?
both Long Lasting tred wear <>depends riding Style & Where most of Riding is done. MUD or Trail?
WELCOME From central upstate N.Y
Many good people & information on the Honda forum.f
RED was the1st color all other colors followed Honda hoes they sell.
20210607 082335 20200725 123146
futzin
futzin
3,248
23,387
Kentucky
I'm running those tires in those sizes, but on 12" aftermarket steelies with 4+3 offset (probably more guys run 5+2). You'll need spacers to run them on the OEM wheels, I'm thinking. I love the tires. Not a good pavement or turf choice, but if your buggy will be used for off-roading then you're golden.
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Are running a square setup?
Reactions: Buggyman
rustyneversleeps
rustyneversleeps
381
1,833
Montana
I'm running same as futzin - HTRs - 27x9x12 up front and 27x11x12 on the rears with 4+3 offset rims....ends up being pretty much even front to back.
G
go21cl
0
mississippi
I recently bought a pioneer 500 and am wondering what the largest tire is that would directly replace the stock tires with the stock rims without any modification? would 27x9-12 front and 27x11-12 rear work? Thanks
Kkettlebell
Kkettlebell
114
475
Nova Scotia
Yeah no problems with 27’s…after that it’s hit or miss depending on the tire
Reactions: go21cl
