P1000 Bed Liner
Glank
Glank
100
340
i used this mat from tractor supply. its a little less than an inch short front to back (seizmik bed extender covers it anyway), and its real rugged/heavy. 1/2" thick.
View attachment 379828View attachment 379829
Nice job. I bought one of these mats and gave up trying to cut it to fit. It's a heavy SOB and doesn't cut easily. It makes a great anti-fatigue mat for the work bench.
fernandw
fernandw
24
134
SE LA
I did the same. Use a jigsaw w/an aggressive wood blade, and it cuts like butter. I did this with a paper template, then used a router with a 3/4" plunger bit while it was in the bed around the edges, to give me the initial gutter around the edge. I then used a straight edge to go from the gutter, out to the rear. This helps to direct the debris and liquids to the rear, with some relief for the "D-rings" on the floor in the rear for it to fit flat.
I found the thinner mats didn't hold up to the chainsaws, machetes, pole saws, logs, coolers and crap we were throwing in the buggy on a daily basis.
IMG 20230326 133952 01
Q
Quailguy
25
68
Ca
Since I'm overly cheap, I found used horse stall mats for sale. I picked out a clean(er) piece and cut it with a razor blade. Stuff is indestructible and cleans easily.
207,989
Anyone coming to the 23 TO that needs or wants a OEM Honda bed liner PM me and you can have it for free, fits a P1-5 and later years
cntryby
cntryby
246
1,880
southeast
Y'all have different needs than me. For farm work I use the front loader.
For the pk1 I found brand new carpet matts, like the ones they use at the door of grocery stores. You can pressure wash them with no issues. I custom fit floor and bed matt. With the heavy rubber on the back, they stay put really good. Carpet keeps the dogs in the back from sliding all over the place. The bed is two piece, but for my purpose it's more than fine.
Honestly, pretty cool to go barefoot with the carpet. 👣
1SJ
6
49
Box Elder, SD
I use a 3/4 inch thick "stall matt" and cut it to size. I make a pattern first out of card board. I cut it with a very sharp box cutter. This stuff is very, very tuff!
Check around at AG supply places, that carry horse stuff.
107,304
Welcome from Michigan
Its your first post, suggest starting a welcome/info thread and post some pics of your rig cuz its Rule #4 when u first post Or..
Pics Or It Didnt Happen.
