P700 Best tire setup for sandy ruts
Smon
9
26
Texas
I have a specific use for my 2019 700-4 deluxe. We use it on a vineyard which ends up getting sandy ruts down the rows. The ruts are not the width of the machine so it is difficult to control sometimes for my wife.
My question is if I need to go with all 4 the same size and space out the rear wheels or keep the stagger. I’m not trying to match the rut width, just have the best setup so there’s a little more control if possible.
We also drive down hard pack and a road, so I was leaning towards 27” terrabites.
155,419
Terrabites look like a flat profile tire which isn't ideal in snow or sand. Flat profile tires tend to dig and are better suited for mud and road running as they'll wear better. A round profile tire will have more flotation and do better in the soft stuff. As for the ruts, your still going to get tossed around a bit but maintaining an even track width will help with navigating them.
Dirtstiffs-1000
Dirtstiffs-1000
1,552
5,646
hondasxs.com
Terrabite profile at 12 psi
Try lowering your tire pressure a bit
20220911 142121
Smon
9
26
Texas
Those terrabites have more curvature than I was expecting. Photos look much more flat online.
I currently have well worn quadboss 447 tires, which seem to have a low load rating as well. They came on the machine when I bought it.
Smon
9
26
Texas
Picked up a set of 27x9 terrabites. Installed a front and a back and realized that the rear wheels must be wider than the front. I thought the wheels were all the same and I would be able to rotate as well as get the same track width.
Is it an issue running the 9” wide tire on these rear wheels? Not much sidewalk bulge. I don’t really care about how it looks, just don’t want to mess up the tire prematurely or cause any other issues.
osobad
osobad
6,618
58,535
Tampa Bay Florida
If using stock wheels I believe offset is different also. When using aftermarket wheels the back needs to be spaced about 1/2 to 1 inch more if using same size tire.
Smon
9
26
Texas
I knew I would need to space the rear wheels out to get the same width, I just didn’t realize the actual wheel widths are different. I kept seeing other say they went the same size all around to rotate, but I’m guessing they also bought wheels with their new tires. Or maybe they are removing tires for a rotation.
osobad
osobad
6,618
58,535
Tampa Bay Florida
new wheels would be my guess
russknight
russknight
1,916
7,541
Perry Florida
Tusk TriloBites are great tires, do very well in sand (not bad in mud either), and are affordable. I have a set on an old Komaski Mule.
Rocky Mountain ATV
Reactions: crewcabrob
crewcabrob
crewcabrob
1,029
4,038
Omaha
Hi,
I have 27" Maxxis Big Horn 3.0 and they do pretty good in sand. But as someone else has pointed out, they are loud on the pavement. And for riding the ridges of ruts, they might not be great.
20211002 190809991 iOS
Smon
9
26
Texas
The more I think about it, I think the most important thing is that my front and tears track the same through the sand. I’m in no danger of getting stuck, so I think the tread means less here. As long as the back isn’t fighting to drop to the left or right, it will feel like she has more control.
the 9” wide on the rear wheels look a little goofy but I’m the only one who cares about that. I just got the new ones mounted so no testing yet out in the sand. I’ll need to pick up some wheel spacers as well.
