P700 Tire Pressure
FeelinRecless
FeelinRecless
178
536
I just got new Tusk Terrabites mounted on my stock deluxe wheels, haven't even put them back on the machine yet. But after getting them home, I thought I should check the PSI, and the tire shop sent them out at 30 psi. Seems like that would feel like running around on solid rubber tires. What is everyone else running? I dropped them down to 10 psi, but I won't even be back to my Pioneer until tomorrow to install them.
Reactions: Farmer
BigEarlX4
BigEarlX4
21
77
St. Helen, MI
  2. Talon X4 LV
Tire pressure is based on the weight of your rig fully loaded, for the Pioneer's generally 7-12psi is what people run. I have played with my pressure up and down in that range and watched wear and 10psi has been the best for my rig and my tires. I had 27" CST Sludge Hammers and currently 30" Super ATV Intimidators and 10psi is what was best for both on hardpack and the road. I drop down to 8psi on certain trails. Hope that helps.
Thorney
Thorney
101
382
Minnesota / Wisconsin
The pressure they put in is just to seat the tires on the rims. 30 psi is not operating pressure. I am running my stock tires at 10psi. You always have to experiment with pressure when you change tires.
I had tires put on one of my ATVs a few years ago, and road down the street on 35 psi after coming home...it felt like I was riding and railroad wheels.
Reactions: FeelinRecless
Farmer
Farmer
2,851
16,389
Southern MO
This a symptom of tire store and small shop zombies....... It's what they do. We run higher pressures (but within sidewall ratings) in our cars for fuel mileage and every time a vehicle goes in somewhere it comes back with 32 psi. They think they're doing you a favor by having the new guy check pressures and fluids but they should simply ask what psi you want. It's just another product of 330 million citizens LOL!
I run 10 psi in most of my atv, sxs, and lawn stuff. 20ish in the big tractors.
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
I think my Tusks are at 12...or as best I remember that's what they were last year when I checked last 😱 . Prolly aughta check again
FeelinRecless
FeelinRecless
178
536
This was pretty much my thought. Mainly curious what others are running.
Mudwing
Mudwing
36,959
306,563
The Mud holes
^this is a good response ^ I run 8.5psi front and 10.5 psi rear. Get a good low pressure tire gage. 😉
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
depends on what your doing . i find my pressure by using a stump or a cinder block and put the corner on the tire eith the tire off the ground then i air down till the tire is about halfway in at the corner section. not sure on the terrabites. but stocks i run like 5-8. my old executioners i was running 6-8 i believe but they could ve ran flat and youd never know unless you were corning hard.
Sent from my E6910 using Tapatalk
FeelinRecless
FeelinRecless
178
536
Started at 10 psi, felt a bit rough. Dropped to 8.5, and left them there. Felt pretty good. Tires are definitely quiter and smoother than the stock OEM tires.
