P700 Bracket on warn plow bent..help?
John12
0
Newark ohio
Has anybody had a similar issue? Bracket holding the pulley bent causing the pulley to fly out where the winch connected to it. Any idea what caused this, possibly an easy fix? Would something like this be under warranty. Thank you for any responses!
064782EB ED42 49D1 8272 871817521EF3
E415F68C CE09 4259 8A79 23C1D07E7065
Ohio4x4
Ohio4x4
I brought the dishwasher
1,494
15,022
Has anybody had a similar issue? Bracket holding the pulley bent causing the pulley to fly out where the winch connected to it. Any idea what caused this, possibly an easy fix? Would something like this be under warranty. Thank you for any responses!View attachment 318401 View attachment 318402
I dont have that plow but my snatch block blew up again while plowing and bent some s*** when the pin came partially out and I didn't see it. My issue was my typical abuse overusing the plow but I could see it happening even with normal use.
DRZRon1
DRZRon1
851
2,739
normal - for me anyway
I tried the plow act on atvs, s x s, and ended up plating, reinforcing, welding, etc. on everyone one of them
most of it was I hit something or pulled up too much on the winch
