P1000 Brake upgrade
samson7x
35
61
Arkansas
Looking for suggestions on upgrading brakes. What are you all doing? Any recs for aftermarket pads that have worked well for you?
Reactions: ChadD and Rayger143
DRZRon1
DRZRon1
846
2,706
PA
Man - talk about skinny pedal down!!!
Please post pics of your ride!!!!!
what’s the reason for upgrading, performance/cornering/mud/short life?
Reactions: Remington and ChadD
samson7x
35
61
Arkansas
Hah! Well I’m probably getting ahead of myself. I just upgraded wheels/tires and figured I may need a little more stopping power with the added weight/height. If it’s common to stick with OEM, then that’s what I’ll do.
03021AF7 F25E 4A1B 8950 49F566ACCFE2 870E4EF2 DBBF 477C 9FB0 7F422092FA6B
P
packer58
301
907
N. Cali
105,169
View attachment 415089 View attachment 415090
Looks good! No upgrade but OEM.
You dont have a bracket lift and stock arms do you?
Reactions: ChadD
105,169
Looks like maybe some rough countries .....with quite a bit of preload ....
Tbey look bit too vertical to be juat tboses with only preload. Even them holy $hit! No spring left hold on to your dentures!
Reactions: ChadD
samson7x
35
61
Arkansas
Stock arms, no bracket lift.
Yes, RC shocks. I actually backed off 1/2” preload from factory and am using that as a starting point. From the thread on here, it looks like a lot of folks are going with about 2” of threads showing. I’m at 1.5” for now.
See above response to packer58. I’m only about 1” lift over factory. These shocks are advertised to give up to 2” so they’re nowhere near maxed out. Either way, I’m still playing around with it.
105,169
Dosnt look like much spring left in the pics.
What size tires you runnin? Look like at least 30’s
Might want to think about aftermarket arms and some spacers or u will rub plus u can fix that crappy stock camber.
Easy there tiger!😉
NoHmo
  • Haha
Reactions: ChadD
samson7x
35
61
Arkansas
Easy there tiger!😉
NoHmo
28x10 KM3 on SB-5 wheels all the way around. Didn’t want to start down the path you describe. Just wanted slightly over stock with no rubbing.
105,169
Not a bad choice in wheels.
That path you dont want to go down is paved with good intentions, not a bad rout to take in the long run😉
Reactions: ChadD
P
packer58
301
907
N. Cali
@samson7x , i'm at 2" of threads below the locking ring and i think i'm getting close to good enough. I do have a fairly heavy DIY tire / gas can rack behind the tailgate.
samson7x
35
61
Arkansas
How much lift did that result in? At 1.5” threads below ring, I’m at a 1” lift. Ride quality so far has been good but I don’t have many miles on it yet. Faster speeds really smooth out. Way better than stock.
Reactions: Rayger143 and ChadD
P
packer58
301
907
N. Cali
Approx 1.5" and within 1/4" of being level measuring below the pipe rail running down both sides of the machine. Deff agree ride is much better than stock.
samson7x
35
61
Arkansas
@samson7x, here's a few pics of the rear rack i put together. It's probably 80 +/- pounds total fully loaded like you see it. Even so, 2" of preload on the rear shocks seems pretty close ........ for now ..View attachment 415385
View attachment 415386View attachment 415387View attachment 415388
Wow, looks great. You fabbed that yourself? I’m a YouTube certified welder and made my rear bumper. Designed to still be able to use tilt bed function. I’ll see if I can dig up a pic when it’s new.
I’m a duck hunter and think a quack rack style project is in my future. About $2000 retail and I priced materials at $200 so can’t beat that.
Edit-pics of custom bumper
1705715289439
1705715313301
Rayger143
Rayger143
2,709
23,452
Winfield, BC Canada
Nice fab work and welds. I wonder why so low?
Reactions: packer58
